Question about AXI transfer
I 'm working with the AXI Master IP and need to replace one 32 bit transaction by 4 separate 8 bits transaction ( ADDR, ADDR+1, ADDR+2, ADDR+3) using only lower 8 bits from Data Bus.
Question is what AXI signals determine the transfer has to be done byte by byte over lower 8-bit data bus?
Re: Question about AXI transfer
Hi @olkhramus,
You can use the strobe signal WSTRB to specify which byte(s) is valid within the transaction.
Please check AXI4 Protocol Specification document for further details about this signal.
Best regards,
Abdallah
Hi @olkhramus,
Best regards,
Abdallah
