Question about Linux on my Zynq
I have Linux running on my Zybo and now I want add a ethernet connection.
In my device tree I found this entry:
ps7_ethernet_1: ps7-ethernet@0xe000c000 {
	clock-names = "ref_clk", "aper_clk";
	clocks = <&clkc 14>, <&clkc 31>;
	compatible = "xlnx,ps7-ethernet-1.00.a";
	interrupt-parent = <&ps7_scugic_0>;
	interrupts = <0 45 4>;
	reg = <0xE000C000 0x1000>;
	status = "disabled";
But I have to modify it a little bit, because I have to add the Phy.
I can´t do the changes in the "ps.dtsi" file, so I have to do it in "system.dts". The whole entry looks like this:
ps7_ethernet_0: ps7-ethernet@e000b000 {
#address-cells = <1>;
#size-cells = <0>;
clocks = <&clkc 13>, <&clkc 30>;
interrupts = <0 22 4>;
local-mac-address = [00 0a 35 00 00 00];
phy-handle = <&phy0>;
phy-mode = "rgmii-id";
reg = <0xe000b000 0x1000>;
xlnx,ptp-enet-clock = <0x6750918>;
xlnx,enet-reset = "";
xlnx,eth-mode = <0x1>;
xlnx,has-mdio = <0x1>;
	mdio {
	#size-cells = <0>;
	phy0: phy@1 {
		compatible = "realtek,RTL8211E";
		device_type = "ethernet-phy";
		reg = <1>;
If I add this to my "system.dtsi" I got an error because of multible definitions of "ps7_ethernet_0".
How can I add this to my "system.dtsi"? Maybe you have an answer for this question.
Many thanks!
Re: Question about Linux on my Zynq
I have solved the problem.
The Clock Source for eth0 was configured for external clock.
After setting this to IO PLL it worked.
Scholar sampatd
Great! Thank you :)
I change my "system.dts" to this:
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Thu Jan 29 07:59:45 2015
/dts-v1/;
/include/ "ps.dtsi"
/include/ "pl.dtsi"
	chosen {
		bootargs = "console=ttyPS0,115200 rootfstype=ext4 root=/dev/mmcblk0p2 rootwait rw";
		linux,stdout-path = &ps7_uart_1;
	aliases {
		ethernet0 = &ps7_ethernet_0;
		i2c0 = &ps7_i2c_0;
		serial0 = &ps7_uart_1;
		spi0 = &ps7_qspi_0;
	ps7_ddr_0: memory@00100000 {
		device_type = "memory";
		reg = <0x0 0x20000000>;
	&ps7_ethernet_0 {
 		mdio {
  		#size-cells = <0>;
 		phy0: phy@1 {
			compatible = "marvell,88e1116r";
 			reg = <1>;
If I try to build the device tree I got this error:
Error: /home/ubuntu/Schreibtisch/Media/Zybo_Linux/Vivado/Zybo/Zybo.sdk/device_tree_bsp_0/system.dts:25.8-23 syntax error
FATAL ERROR: Unable to parse input tree
 What is the reason for this error?
Thank you again :)
No idea :(?
I doesn´t know much about device tree, so I don´t know where my mistake is.
I add the part for the Phy now:
 * Version:
 * Today is: Fri Feb  6 14:34:05 2015
/dts-v1/;
/include/ "ps.dtsi"
/include/ "pl.dtsi"
&ps7_ethernet_0 {
	xlnx,ptp-enet-clock = <108333336>;
	mdio {
		#size-cells = <0>;
		phy0: phy@1 {
			reg = <1>;
	chosen {
	aliases {
		i2c0 = &ps7_i2c_0;
		spi0 = &ps7_qspi_0;
Now I can compile the device tree, but when I boot my Zybo I can't ping it.
The Zybo has a fix IP and I can't ping from the Zybo.
During boot the system doen't show that there is no phy installed, so I think the phy should work.
What is the problem now?
Thank you!
Scholar sampatd
you should be able to change the IP of your board using 'ifconfig'
for example, at zynq prompt:
ifconfig eth0 192.168.10.11 up
You can also set-up the ip address in bootargs.
thank you for your answer.
I did it:
root@Zybo:/# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          inet addr:192.168.178.50  Bcast:192.168.178.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:54 Base address:0xb000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:9 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1008 (1008.0 B)  TX bytes:1008 (1008.0 B)
root@Zybo:/# ping 192.168.178.1
PING 192.168.178.1 (192.168.178.1) 56(84) bytes of data.
^C
--- 192.168.178.1 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2005ms
 But the ping to my router doesn´t work :(
