Visitor rocco0815
RTOS - lwIP - max THREAD_STACKSIZE
Hey there,
I am running Xilinx SDK 2016.4 with Zynq7020 and using the lwIP echo test example for RTOS on Core0.
So far so good, in my main there is a "main_thread" created, so echo test works fawless.
int main()
	// initialize THREADS
	sys_thread_new("main_thrd", (void(*)(void*))main_thread, 0,
	                THREAD_STACKSIZE,
					DEFAULT_THREAD_PRIO);
	vTaskStartScheduler();
	while(1);
	return 0;
In this thread I am checking what data has been sent and run the corresponding functions. Now my problem is: One of my functions causes an "vApplicationStackOverflowHook" exception. So I've checked all my pointers / arrays I am using in there, the problem seems to be the used memory of my function (doing some calculations and measurements).
Now my question is:
Is there any possibility to enhance the STACK_SIZE of the RTOS thread I am running?
I already have increased the THREAD_STACKSIZE from 1024 to 2048 but it isn't enough. So any larger number than 2048 will force the RTOS not to execute thte thread correct: Meaning I cannot connect to my echo server when STACK_SIZE is larger than 2048.
#define THREAD_STACKSIZE 1024
By the way: the THREAD_STACKSIZE is defined in echo.c and also in main.c (from xilinx example)
So someone got succesfully configured a THREAD_STACKSIZE larger than 2048 ?
BTW here is my Linkerscript for RTOS:
/* This file is automatically generated by linker script generator.*/
/* Version:                                 */
/* Copyright (c) 2010-2016 Xilinx, Inc.  All rights reserved.      */
/* Description : Cortex-A9 Linker Script                          */
_STACK_SIZE = DEFINED(_STACK_SIZE) ? _STACK_SIZE : 0x200000;
_HEAP_SIZE = DEFINED(_HEAP_SIZE) ? _HEAP_SIZE : 0x80000;
_ABORT_STACK_SIZE = DEFINED(_ABORT_STACK_SIZE) ? _ABORT_STACK_SIZE : 1024;
_SUPERVISOR_STACK_SIZE = DEFINED(_SUPERVISOR_STACK_SIZE) ? _SUPERVISOR_STACK_SIZE : 2048;
_IRQ_STACK_SIZE = DEFINED(_IRQ_STACK_SIZE) ? _IRQ_STACK_SIZE : 1024;
_FIQ_STACK_SIZE = DEFINED(_FIQ_STACK_SIZE) ? _FIQ_STACK_SIZE : 1024;
_UNDEF_STACK_SIZE = DEFINED(_UNDEF_STACK_SIZE) ? _UNDEF_STACK_SIZE : 1024;
/* Define Memories in the system */
MEMORY
   ps7_ddr_0_S_AXI_BASEADDR : ORIGIN = 0x200000, LENGTH = 0xE00000
   ps7_ram_0_S_AXI_BASEADDR : ORIGIN = 0x0, LENGTH = 0x30000
   ps7_ram_1_S_AXI_BASEADDR : ORIGIN = 0xFFFF0000, LENGTH = 0xFE00
/* Specify the default entry point to the program */
ENTRY(_vector_table)
/* Define the sections, and where they are mapped in memory */
SECTIONS
.text : {
   KEEP (*(.vectors))
   *(.boot)
   *(.text)
   *(.text.*)
   *(.gnu.linkonce.t.*)
   *(.plt)
   *(.gnu_warning)
   *(.gcc_execpt_table)
   *(.glue_7)
   *(.glue_7t)
   *(.vfp11_veneer)
   *(.ARM.extab)
   *(.gnu.linkonce.armextab.*)
} > ps7_ddr_0_S_AXI_BASEADDR
.init : {
   KEEP (*(.init))
.fini : {
   KEEP (*(.fini))
.rodata : {
   __rodata_start = .;
   *(.rodata)
   *(.rodata.*)
   *(.gnu.linkonce.r.*)
   __rodata_end = .;
.rodata1 : {
   __rodata1_start = .;
   *(.rodata1)
   *(.rodata1.*)
   __rodata1_end = .;
.sdata2 : {
   __sdata2_start = .;
   *(.sdata2)
   *(.sdata2.*)
   *(.gnu.linkonce.s2.*)
   __sdata2_end = .;
.sbss2 : {
   __sbss2_start = .;
   *(.sbss2)
   *(.sbss2.*)
   *(.gnu.linkonce.sb2.*)
   __sbss2_end = .;
.data : {
   __data_start = .;
   *(.data)
   *(.data.*)
   *(.gnu.linkonce.d.*)
   *(.jcr)
   *(.got)
   *(.got.plt)
   __data_end = .;
.data1 : {
   __data1_start = .;
   *(.data1)
   *(.data1.*)
   __data1_end = .;
.got : {
   *(.got)
.ctors : {
   __CTOR_LIST__ = .;
   ___CTORS_LIST___ = .;
   KEEP (*crtbegin.o(.ctors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .ctors))
   KEEP (*(SORT(.ctors.*)))
   KEEP (*(.ctors))
   __CTOR_END__ = .;
   ___CTORS_END___ = .;
.dtors : {
   __DTOR_LIST__ = .;
   ___DTORS_LIST___ = .;
   KEEP (*crtbegin.o(.dtors))
   KEEP (*(EXCLUDE_FILE(*crtend.o) .dtors))
   KEEP (*(SORT(.dtors.*)))
   KEEP (*(.dtors))
   __DTOR_END__ = .;
   ___DTORS_END___ = .;
.fixup : {
   __fixup_start = .;
   *(.fixup)
   __fixup_end = .;
.eh_frame : {
   *(.eh_frame)
.eh_framehdr : {
   __eh_framehdr_start = .;
   *(.eh_framehdr)
   __eh_framehdr_end = .;
.gcc_except_table : {
   *(.gcc_except_table)
.mmu_tbl (ALIGN(16384)) : {
   __mmu_tbl_start = .;
   *(.mmu_tbl)
   __mmu_tbl_end = .;
.ARM.exidx : {
   __exidx_start = .;
   *(.ARM.exidx*)
   *(.gnu.linkonce.armexidix.*.*)
   __exidx_end = .;
.preinit_array : {
   __preinit_array_start = .;
   KEEP (*(SORT(.preinit_array.*)))
   KEEP (*(.preinit_array))
   __preinit_array_end = .;
.init_array : {
   __init_array_start = .;
   KEEP (*(SORT(.init_array.*)))
   KEEP (*(.init_array))
   __init_array_end = .;
.fini_array : {
   __fini_array_start = .;
   KEEP (*(SORT(.fini_array.*)))
   KEEP (*(.fini_array))
   __fini_array_end = .;
.ARM.attributes : {
   __ARM.attributes_start = .;
   *(.ARM.attributes)
   __ARM.attributes_end = .;
.sdata : {
   __sdata_start = .;
   *(.sdata)
   *(.sdata.*)
   *(.gnu.linkonce.s.*)
   __sdata_end = .;
.sbss (NOLOAD) : {
   __sbss_start = .;
   *(.sbss)
   *(.sbss.*)
   *(.gnu.linkonce.sb.*)
   __sbss_end = .;
.tdata : {
   __tdata_start = .;
   *(.tdata)
   *(.tdata.*)
   *(.gnu.linkonce.td.*)
   __tdata_end = .;
.tbss : {
   __tbss_start = .;
   *(.tbss)
   *(.tbss.*)
   *(.gnu.linkonce.tb.*)
   __tbss_end = .;
.bss (NOLOAD) : {
   __bss_start = .;
   *(.bss)
   *(.bss.*)
   *(.gnu.linkonce.b.*)
   *(COMMON)
   __bss_end = .;
_SDA_BASE_ = __sdata_start + ((__sbss_end - __sdata_start) / 2 );
_SDA2_BASE_ = __sdata2_start + ((__sbss2_end - __sdata2_start) / 2 );
/* Generate Stack and Heap definitions */
.heap (NOLOAD) : {
   . = ALIGN(16);
   _heap = .;
   HeapBase = .;
   _heap_start = .;
   . += _HEAP_SIZE;
   _heap_end = .;
   HeapLimit = .;
.stack (NOLOAD) : {
   . = ALIGN(16);
   _stack_end = .;
   . += _STACK_SIZE;
   . = ALIGN(16);
   _stack = .;
   __stack = _stack;
   . = ALIGN(16);
   _irq_stack_end = .;
   . += _IRQ_STACK_SIZE;
   . = ALIGN(16);
   __irq_stack = .;
   _supervisor_stack_end = .;
   . += _SUPERVISOR_STACK_SIZE;
   . = ALIGN(16);
   __supervisor_stack = .;
   _abort_stack_end = .;
   . += _ABORT_STACK_SIZE;
   . = ALIGN(16);
   __abort_stack = .;
   _fiq_stack_end = .;
   . += _FIQ_STACK_SIZE;
   . = ALIGN(16);
   __fiq_stack = .;
   _undef_stack_end = .;
   . += _UNDEF_STACK_SIZE;
   . = ALIGN(16);
   __undef_stack = .;
_end = .;
