Visitor jar3dp
Read DDR from PL on Zynq
I am new to the zynq platform and am trying to read from the DDR memory from PL. I do not need to do any writes, just reads. I have been sifting through the forums looking for a solution, and while there are several similar threads, I am still a little confused. I would greatly appreciate an explanation of how this can be done. I am using a ZYBO board, if that matters. Thank you.
Tags (4)
Scholar watari
Re: Read DDR from PL on Zynq
Hi @jar3dp
Would you try to use AXI DMA controller ?
I'm sure that it is useful to resolve what you want to do.
Thank you.
Best regards
You can use the CDMA. There is example driver code that you can use to help you here:
SDK\2017.1\data\embeddedsw\XilinxProcessorIPLib\drivers\axicdma_v4_3\examples
Visitor jar3dp
@watari and @stephenm, thanks for your replies, but my application requirements are such that I must access DDR strictly from the PL. The problem with that CMDA example is it requires lots of software setup. Is there a way to use the CDMA strictly from the PL side? Thanks.
what do you mean stricty from the PL side? Do you mean you dont want to use the processor to configure the DMA?
This is why I suggested the CDMA. It doesnt need the processor. The CDMA is also in the PL too (ie a soft IP)
Visitor jar3dp
Yes I mean I can't use the processor to configure the DMA. The example you pointed me to however is C code. I've instantiated a CDMA block, and am unsure exactly how to go about connecting everything up.
