Visitor t-nehada
Receive a USB data buffer using ep0
Hi all,
I am using this example to manage the USB on my device:
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/usbps/examples/xusbps_intr_example.c
Now I try to send a SetFeature command over hid(using HidD_SetFeature) from the host side.
So to do that, because features commands arrived to the end-point 0, I changed the function XUsbPs_Ep0EventHandler() to hold the data from RX:
case XUSBPS_EP_EVENT_DATA_RX:
			Status = XUsbPs_EpBufferReceive(InstancePtr, EpNum, &BufferPtr, &BufferLen, &Handle);
			if (XST_SUCCESS == Status)
				// My changes start
				u8* pRecvData = NULL;
				if ((REPORT_ID__NCP_INOUT_15 == BufferPtr[0]))
					Xil_DCacheInvalidateRange((unsigned int)BufferPtr, BufferLen);
					pRecvData = (u8*)MM_RequestMemory_Original(MM_MEMORY_TYPE__1KB, TRUE);
					if (pRecvData != NULL)
						memcpy(pRecvData, BufferPtr, BufferLen);
						InsertQueue_USBData_receive(EpNum, pRecvData, BufferLen, Handle);
				// My changes end
				XUsbPs_EpBufferRelease(Handle);
			break;
And I have two questions:
  1. This is the right way to do that? maybe I need to copy the buffer from another place?
  2. When I try to send many commands in a sequence, sometimes the buffer arrived with zeros values(Only the values in buffer of data. The length is obtained right).
Someone saw that problem and can pour me some light?
Thank you very much!
Netanel.
