09-28-2018 01:46 AM
Hello everyone,
I am having an XADC running in event-mode with enabled interrupt. My problem is, everytime I change some configuration/also when I do not change something, I have to reprogram the FPGA with the same binary file again. Or otherwise the bare-metal code is not running.
Does someone know why?
09-28-2018 02:01 AM - edited 09-28-2018 02:02 AM
Don't you flash your config and set the FPGA boot mode to load it from there?
Or do you mean your config only runs when downloaded via JTAG and not otherwise?
In that case... have you attached your elf file to the bitstream?
09-28-2018 02:44 AM
It didn't do something wrong.
When I choose the continous mode, or a gpio project. I only have to flash the FPGA once. Afterwars I only have to run the system debugger.
In this case, that I use the event-mode with interrupts, I have to flash the FPGA every time, before program with the system debugger.
I also attached the elf file to bitstream.
