Visitor onofognol
Run bare-metal program from OCM using the SDK flow?
I'm trying to exercise the SODIMM on my ZC706, and to do so properly, it would be ideal to have no PS.  Unfortunately, it appears that I need to have a PS to use the UART, or any other peripherals I might use to log my results.
Is there a way to write a small program in the HLS/SDK flow (say, that just reads from an AXI interface and writes to the UART), and have it run entirely in the OCM, Flash, or pinned in the cache?
I looked at some sources from the Xilinx wiki, but it is not clear how I would set something like this up with the SDK tool chain.
Re: Run bare-metal program from OCM using the SDK flow?
Hi @onofognol ,
Yes, you can run the applications from OCM. Create an application in SDK to read from PL Slave ( you can use Xil_In32 and Xil_Out32 functions to read write from any PL address). after this go to the inker script (ld file) and change the memory entries to OCM then this application will runs from OCM.
also Please refer this: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842377/Zynq-7000+AP+SoC+Boot+-+Booting+and+Running+Without+External+Memory+Tech+Tip
Best Regards,
Srikanth
Hi @onofognol ,
Best Regards,
Srikanth
