Voyager
Voyager
Running the Xapp1026 on 13.4 ISE
I am facing a problem running the simple echo server in the ISE 13.4 . Can the design files provided in the application notes of Xapp1026 be used in the 13.4 version without any errors? When i compiled the files there were so many errors, some as critical as not able to find some of the include files of the IwIP   in the installed libraries of 13.4. Please help me in this regard. Is there a place to download the design files for the 13.4 version?
Voyager
Voyager
Re: Running the Xapp1026 on 13.4 ISE
Hey
Its okay i solved the problem. I used the 13.1 version and it worked without any problems :)
What are the error messages you see in 13.4?
Nan
"Don't forget to reply, kudo and accept as solution."
Voyager
Voyager
Hey
