S_AXI_LPD Interface to DDR memory
Can we use S_AXI_LPD port in Zynq US+ device to send/receive data from PL directly to DDR Memory? Performance is not a major constraint for the data transfer. When I look at Figure 35-6: AXI-HP and HPC Interfaces and Data Movement Topology in TRM, I don't see a connection between the S_AXI_LPD and DDR controller in PS.
But, When I create simple design in PL to send the data through S_AXI_LPD port the DDR memory address locations, I could see the data at the DDR even with no software running on RPU. Very basic software accessing DDR running on APU.
Scholar jmcclusk
Re: S_AXI_LPD Interface to DDR memory
The block diagrams may be confusing, but the fabric AXI ports can absolutely access the DDR memory on the PS side.   It works.   Just beware of bandwidth, since it's shared with the processors and the dma engines.
Scholar jmcclusk
Thank you! Is there a documentation explaining the max throughput/data rate that can be achieved using each AXI Interface ?
Scholar jmcclusk
There is a Wiki page that describes how to do performance modelling:
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+-+System+Performance+Modelling
Thank you for the pointer !
