Observer dandahl
SDK 2016.1 (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specified for 'object'.
After exporting with bit-stream to SDK I get this message when trying to build a new BSP or Project and it fails every time. This message appears to be related to a space in a name somewhere and I can't figure out where. The output of the log file: 05:07:11 INFO : Launching XSDB server: xsdb.bat -interactive C:\Projects\FSA\FSA_adc_hw_2016_1\FSA_adc_hw.sdk\temp_xsdb_launch_script.tcl 05:07:12 INFO : XSDB server has started successfully. 05:08:19 INFO : Launching XSDB server: xsdb.bat -interactive C:\Projects\FSA\FSA_adc_hw_2016_1\FSA_adc_hw.sdk\temp_xsdb_launch_script.tcl 05:08:20 INFO : XSDB server has started successfully. 05:08:20 INFO : Processing command line option -hwspec C:/Projects/FSA/FSA_adc_hw_2016_1/FSA_adc_hw.sdk/FSA_adc_hw_0_wrapper.hdf. 05:09:03 ERROR : (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specified for 'object'. ERROR: [Hsi 55-1545] Problem running tcl command ::sw_axiethernet_v5_1::generate : ERROR: [Common 17-161] Invalid option value '' specified for 'object'. while executing "get_property IP_TYPE $pname_type" ("foreach" body line 4) invoked from within "foreach intr_sink $intc_port { set pname_type [::hsi::utils::get_connected_intr_cntrl $target_periph $intr_sink] if {$pname_type != ..." ("foreach" body line 9) invoked from within "foreach intr_port $interrupt_port { set interrupt_signal_name [get_property NAME $intr_port] set intc_port [get_pins -of_objects $targ..." (procedure "xdefine_dma_interrupts" line 20) invoked from within "xdefine_dma_interrupts $file_handle $target_periph $device_id $canonical_tag $dmarx_signal $dmatx_signal" ("foreach" body line 88) invoked from within "foreach periph $periphs { set p2p_periphs [list] set periph_name [string toupper [get_property NAME $periph]] # Get all point2point b..." (procedure "xdefine_axi_target_params" line 17) invoked from within "xdefine_axi_target_params $periphs $file_handle" (procedure "xdefine_axiethernet_include_file" line 47) invoked from within "xdefine_axiethernet_include_file $drv_handle "xparameters.h" "XAxiEthernet"" (procedure "::sw_axiethernet_v5_1::generate" line 3) invoked from within "::sw_axiethernet_v5_1::generate axi_ethernet_0" 05:09:03 ERROR : (XSDB Server)ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate() ERROR: [Hsi 55-1450] Error: running generate_bsp. 05:09:03 ERROR : Error generating bsp sources: Failed in generating sources 05:09:03 ERROR : Failed to generate sources for BSP project fsa_firmware_bsp_0 org.eclipse.core.runtime.CoreException: Internal error occurred while generating bsp sources. Please check the SDK Log view for further details. at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.internalGenerateBsp(RegenBspSourcesHandler.java:178) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler.access$2(RegenBspSourcesHandler.java:163) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1$1.run(RegenBspSourcesHandler.java:131) at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241) at com.xilinx.sdk.sw.ui.handlers.RegenBspSourcesHandler$1.run(RegenBspSourcesHandler.java:135) at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119) I would appreciate if someone could help. -Dan
Observer dandahl
Re: SDK 2016.1 (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specified for 'object'.
Thank you for translating that message for me. I did not understand what it was trying to tell me. Looking at my project I found that there were actually three interrupts that I had missed connection to. This got me through to the next/new problem. It now can't PAR an ILA anymore. I get strange errors, but that will be a different post.
-Dan
Observer dandahl
I didn't realize that the message was going to get all mashed up like it did so here is the output of the log file in readable format. I didn't preview before posting. I am not a TCL expert of any kind. Can anyone please help.
08:49:48 INFO  : Launching XSDB server: xsdb.bat -interactive C:\Projects\FSA\FSA_adc_hw_2016_1\FSA_adc_hw.sdk\temp_xsdb_launch_script.tcl
08:49:50 INFO  : XSDB server has started successfully.
08:50:37 INFO  : Project 'FSA_adc_hw_0_wrapper_0' created. You can now create BSPs and application projects targeting this hardware platform.
08:50:53 ERROR : (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specified for 'object'.
    while executing
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
08:50:53 ERROR : (XSDB Server)ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
08:50:53 ERROR : (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.
08:50:53 ERROR : Error generating bsp sources: Failed in generating sources
08:50:53 ERROR : Failed to generate sources for BSP project standalone_bsp_0
Scholar stephenm
Can you post the HDF file when exporting to sdk?
Looks like your hw isn't set up coirectly. The tools seems to be complaining about your interrupts.
Observer dandahl
-Dan
