Newbie dutcher
SPI flash memory
Hi everyone,
Thanks for reading my post. I'm trying to make a DAC (digital analog converter) for better sound quality.
Everything goes well for so far. But there is one part I don't understand.
The processor Is communicating with the flash memory (IS25LQ016B). And I need to program this chip to let it work properly.
I have the files and the software to do that so that will not be a big deal. I will use a CH341A spi flash programmer from aliexpress to do the job.
But I need to enable 4-bit or quad-IO mode as well :/
I have read that this is not possible with the CH341A.
My questions:
How can I enable the 4-bit or quad-IO mode without breaking the bank.
Can someone give me some information about the 4-bit or quad-IO. I have no idea what it does and why it has to be enabled.
thanks for the comments.
kind regards
Re: SPI flash memory
Hey @dutcher,
To program the IS25LQ016B, there is no need to use QuadSPI as it also support single and dual SPI modes.
It is basically a high throughput (parallel) mode which uses four instead of a single data line.
You can enable it with some commands when the hardware supports it.
Hope this clarifies,
Herbert
Newbie dutcher
Thanks for your reply @hpoetzl,
Thanks for the explanation.
Are you sure I don't need to enable 4-bit or quad-IO? (see screenshot)
Newbie dutcher
Do you mean the hardware of the DAC or the hardware of the SPI flash programmer?
Newbie dutcher
the IS25LQ016B is communicating with the XHRA-2HPA.
I think the XHRA-2HPA requires Quadspi
Hey @dutcher,
Just to clarify ...
  • The IS25LQ016B is Single/Dual/Quad SPI capable.
  • You can program the IS25LQ016B in Single/Dual/Quad mode.
  • You can configure Quad SPI via Bit 6 (QE) of the Status Register.
  • The XHRA-2HPA requires Quad SPI.
  • The programmer hardware needs to be compatible with the SPI.
  • The CH341A (chip) is 3.3V and compatible with the IS25LQ016B.
Best,
Herbert
Newbie dutcher
Thanks for your reply,
Can I use batronix prog-express with the CH34 to generate firmware image?
what is the easiest way to enable QSPI?
kind regards,
Hey @dutcher,
You're welcome!
No idea what that is or does ...
Setting bit #6 of the Status Register (QE)
Hope this helps,
Herbert
