07-23-2018 06:00 AM
I have a ZCU102 Board and want to use a SPI on a PMOD-Connector. For this i took the QuadSPI.
When running with the loopback flag everything is running fine, but when i remove the loopback and use a
connection from MOSI to MISO i always receive 0. What could be the problem ?
First picture D0=MOSI,D1=MISO,D2=CLK,D3=SEL.
This is the Constraint File for PMOD0 :
set_property PACKAGE_PIN A20 [get_ports spi_mosi]
set_property PACKAGE_PIN B20 [get_ports spi_miso]
set_property PACKAGE_PIN A22 [get_ports spi_sck]
set_property PACKAGE_PIN A21 [get_ports spi_sel]
set_property IOSTANDARD LVCMOS33 [get_ports spi_mosi]
set_property IOSTANDARD LVCMOS33 [get_ports spi_miso]
set_property IOSTANDARD LVCMOS33 [get_ports spi_sck]
set_property IOSTANDARD LVCMOS33 [get_ports spi_sel]
07-31-2018 04:34 AM
Hi bader@gctnet.de,
If you remove loopback then how are you configuring the mode of transfers in SPI?
Is it in normal mode?
Praveen
07-31-2018 07:28 AM
I only set the MasterOption:
The SPI IP is in Standard-Mode ( not Dual or Quad ), XIP and Performance mode is disabled.
And this is the setting in the SDK:
Status = XSpi_SetOptions(&Spi_PL, XSP_MASTER_OPTION );
07-31-2018 08:46 AM
Here is a part of my serial output:
TX: 0x01 0x55 0x02 0xAA
xRX: 0x00 0x00 0x00 0x00
[0x60]=0x0106 [0x64]=0x0025 [0x70]=0x0001 [0x74]=0x0000 [0x78]=0x0000 [0x1C]=0x80000000 [0x20]=0x0000
[0x28]=0x002B.
[Register] = Value
The "x" before RX indicates an Interrupt. For starting I used the example code from "xspi_intr_example.c"
08-06-2018 10:49 PM
08-06-2018 11:36 PM
Did you enable the XILISF library on the BSP?
No i didn't enable this Library before because i hadn't found any reference to it. But i have tested it now with enabled xilifs
and it is the same -> no Input, always 0.
When you ran the example application, did it get executed successfully? If not, at what stage does it fail?
This example is not a real example, because it only uses loopback ( as you can find in the posts above ).
And this works. Please read the posts above for all informations i already posted. And as you can see, everything is running
even the interrupt is working, only the input doesn't work !
08-13-2018 04:52 AM
08-13-2018 05:17 AM
Can you please share the application that you run?
I cannot share the application, because for me i throw this IP to waste and programmed one for myself in the meantime !
But i think it is a bug, so you should look for it.
I will target that to one of our evaluation boards and see where it is going wrong.
Simply connect the QuadSPI as a single SPI in standard mode. Then connect MOSI to MISO. No Flash to read or write. I already
described this in the first post.
It's not a loopback. Can you please point to the reference where it runs a loopback?
As explained above i used the example : xspi_intr_example.c ( see below)
// Run loopback test only in case of standard SPI mode.
if (SpiInstancePtr->SpiMode != XSP_STANDARD_MODE) {
return XST_SUCCESS;
// Connect the Spi device to the interrupt subsystem such that
// interrupts can occur. This function is application specific.
Status = SpiSetupIntrSystem(IntcInstancePtr,SpiInstancePtr,SpiIntrId);
if (Status != XST_SUCCESS) {
return XST_FAILURE;
* Setup the handler for the SPI that will be called from the interrupt
* context when an SPI status occurs, specify a pointer to the SPI
* driver instance as the callback reference so the handler is able to
* access the instance data.
XSpi_SetStatusHandler(SpiInstancePtr, SpiInstancePtr,
(XSpi_StatusHandler) SpiIntrHandler);
* Set the Spi device as a master and in loopback mode.
Status = XSpi_SetOptions(SpiInstancePtr, XSP_MASTER_OPTION | XSP_LOOPBACK_OPTION);
return XST_FAILURE;
But as i explained above, it doesn't work without loopback, and as i further explained above, everything works i even get an interrupt, but the received data is alway 0. . I looks like the input pin i not lead back to the IP.
08-20-2018 04:31 AM
08-20-2018 09:26 AM
In the meantimne i have built a testapplication too. And it is the same. How can i simply post a complete
project with SDK-Code and so on ?
08-20-2018 10:03 PM
08-28-2018 04:51 AM
09-25-2018 01:59 AM
Do you have an idea whats happening ?
I still cannot use this IP !
