Participant barrygmoss
Setting clock frequency for a BRAM_CTRL interface in IP Integrator
I have a block design with two BRAM True Dual Generator blocks. One port of each goes to an AXI BRAM Controller. The other port is brought out as an external port to be interfaced to custom Verilog logic.
The problem that I'm having is that I can't seem to find anyway to set the clock frequency for the external BRAM interfaces. Hence, I'm getting warnings because the clock rate that I'm actually operating at is much higher than the default 20 MHz that Vivado assigns to this port during OOC generation of the block outputs. How can I specify a clock frequency for this interface so that my OOC generation will run with a reasonable constraint?
Re: Setting clock frequency for a BRAM_CTRL interface in IP Integrator
You can right click on the ipi fabric, and select create port. Set the type to clock, direction as out. You can the connect this to your clock source
Thanks for the suggestion, Stephen.
I assume that this means I need to break out the entire BRAM interface as individual ports then? Or is there some way to just isolate the clock port of the BRAM interface? I certainly don't want to have duplicates of that port once I've generated the BD. I've run into some problems before trying to access one signal of a full interface.
Barry
Where are you seeing the error? Only the input clocks in IPI would care about the frequency.the clock frequency of the clk_a/b will be the same as the input clock to the controller.
