Standalone SD card read & test program fails
I am trying to using standalone program to test the SD card read and write speed, the program is as follow
   // SDIO Controller Test
   static XSdPs ps7_sd_0;
   XSdPs_Config * SdConfig_0;
   u8 RxBuffer[512*2];
   int Status;
   SdConfig_0 = XSdPs_LookupConfig(XPAR_PS7_SD_0_DEVICE_ID);
    if (NULL == SdConfig_0) {
        return XST_FAILURE;
    Status = XSdPs_CfgInitialize(&ps7_sd_0, SdConfig_0, SdConfig_0->BaseAddress);
    if (Status != XST_SUCCESS) {
        print("Sd Config failed !\n\r");
        return XST_FAILURE;
    Status = XSdPs_SdCardInitialize(&ps7_sd_0);
        print("Sd0 Initialization failed !\n\r");
        return XST_FAILURE;
    // read and write test
    Status = XSdPs_ReadPolled(&ps7_sd_0, 0x01, 0x01, RxBuffer);
        print("Sd1 Read failed !\n\r");
        return XST_FAILURE;
The last read function fails, anyone knows why ? Thanks.
Re: Standalone SD card read & test program fails
Can you share more details, as which board? which version?
--Hem
I am using Zedboard (rev c) with vivado 2013.4. All the setting are default zedboard configuration.
The SD card works fine since the board can boot from it.
Xilinx does not proivde examples for sdio devices in the SDK document.
- doonny
Observer soteria0
I am facing the same problem while crating a test program for SD card. I am using ZC706 board and using SDK 2014.2 version. The function call XSdPs_CfgInitialize(XSdPs *InstancePtr, XSdPs_Config *ConfigPtr, u32 EffectiveAddr) is failled in my case. The function does not return any thing....
Can anyone have solution for this?
Monjur
Hi soteria0,
Sorry for the delayed reply. You can find a detailed tutorial with source code on how to use the SD card on a standalone SDK project targeting the Zynq7000 (Zedboard ) on this link http://embeddedcentric.com/data-logging-using-sd-cards/
Ali
