Stopping an HLS IP Core with the PS
I created, with Vivado HLS, an IP core that performs a calculation in the PL. This calculation needs to be stop whenever I want even if it hasn't been terminated. The module is controlled by the PS and has an AXI4Lite interface. In the driver file, I have a function to start the calculation but not to stop it.
I tried something like putting the code in a while loop. The while loop has a stop condition controlled by an input.
void foo(input1, input2,.., output)
 stop = 1;
   while(input1 && stop)
  //calculation
 //if calculation is over, stop = 0
But it doesn't work, because the function checks the inputs only when the start function is called in the PS. So I can't change the value of the stop condition when I want before the end.
I also tried something with the reset pin but it was a failure as well.
Do you have any idea how to do so ?
John
Teacher muzaffer
Re: Stopping an HLS IP Core with the PS
with an or block you can't make the output zero. I guess I wasn't clear when I mentioned 'or'ing. Given that aresetn is active low, you need an "AND" gate with one input connected to ARESETN and the other input connected to GPIO_O pin. The default value of GPIO_O should be high. This allows ARESETN to control the state. When you want to override the current high state of output, you can write a zero to the GPIO_O which makes the output of the gate go low.
Teacher muzaffer
if you want to arbitrarily stop the ip, you can actually reset it manually but you have to add that logic yourself. This can be accomplished by adding a gpio somewhere in the design and 'or'ing the output of gpio with the aresetn signal of the IP. This way when you write to the gpio, the block will be reset.
Thanks for your answer muzaffer.
I tried your method. Unfortunately, it didn't work.
I added a gpio and connected the gpio_io_o pin to an OR block that I created. The second input of the OR block is connected to aresetn. The output is then connected to the reset pin of my hls module.
But when XGpio_DiscreteWrite is called, no reset is done and the module continue its calculation.
A solution ?
Teacher muzaffer
Thank you very much muzaffer for your explanation. It worked perfectly.
