Visitor paxuli
Succesive writes and reads in the Qspi flash memory
Hello. I'm trying to execute the example "xqspips_flash_lqspi_example.c". It works fine if you execute the example one time but I need to write and read many times in the same address region of the Qspi. When I try to write and read more than one time in the test_address region of the example I am not able to write and read new data. I get the previous data in the ReadBuffer. However, if I Try to write to a different region, I am able to do it and I get the new data  in the ReadBuffer that I pretend to write.
Thanks in advance.
Re: Succesive writes and reads in the Qspi flash memory
Can you send me the workspace?
--HS
Visitor fourrunner72
was there ever a solution to this issue?
I am currently seeing the same thing
fyi, issue went away when i used the xqspips_g128_flash_example.c as an example reference
