TEMAC example design Zynq
Hi!
I need to do a design with Zynq and Tri-mode Ethernet Mac (TEMAC) in Vivado to use it later with Linux.  I want to connect a Ethernet FMC with DP8360 PHY (mii connection). Does anyone have any examble block design?
Re: TEMAC example design Zynq
Hi @allende.imanol,
XAPP1082 could be a very good reference.
https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Have you had a look at this?
"Don't forget to reply, kudo and accept as solution."
