The GPIO ISR(Interrupt Service Routines) doesn't run as expected?
I'm puzzled about the GPIO interrupt.
I'm trying to generate an interrput signal in PL and transfer it to PS thru GP AXI Master Port.
When I make instantiation of GPIO IP core in XPS(EDK), I selected the 'GPIO Supports Interrupt', just as what is showed following.
And then, I make a connection between GPIO intr and GIC (Generic Interrupt Controller), just as what is showed following. In my C code in SDK, the C code is able to catch the interrupt signal successfully.
But the ISR(Interrupt Service Routines) doesn't run as expected.
About the C code, I almost imitate the following example.
            14.2\ISE_DS\EDK\sw\XilinxProcessorIPLib\drivers\gpio_v3_00_a\examples\xgpio_intr_example.c
Anyone help me to check out what the problem is?
Thanks very much.
Re: The GPIO ISR(Interrupt Service Routines) doesn't run as expected?
Hey
I added a similar project I added my own ip that I want use in interruption, for add my own ip I create and importe peripheral with the XPS. Now I serach example in c language who use a custom peripheral added create and import peripheral.
Best regards.
