Tracking MicroBlaze instruction insert exception
We are developing a custom PCB that is designed to take in DisplayPort video into a Kintex 7 FPGA
(p/n xc7k160tffg676-2).  The board will eventually include DDR memory - however, we are building up our board in stages and I'm trying to get the project to run using only local BRAM memory.
- To make sure there's enough space reserved for the program and the heap and stack, I've set the memory addresses for the data and instructions parts of BRAM to be 1 Megabyte, as shown in this image from the Vivado project.
bram_addresses.PNGBRAM addresses
Upon building the software project, SDK reports the size as 504072 bytes.
mb-size dprx.elf  |tee "dprx.elf.size"
   text	   data	    bss	    dec	    hex	filename
  78474	    920	 424678	 504072	  7b108	dprx.elf
And I've set the heap and stack to each be 180 kilobytes in size.  So I believe everything should fit within the BRAM memory that I have reserved.
However, when I begin to 'Debug as' the project, I end up stepping through the code and as I get to (seemingly) random points in the execution, I get the following error in the Disassembly window:
insert_exception_error.PNGMicroBlaze instruction insert exception
Based on other posts on the forum, I thought this might have been due to bad interrupts in the system and I've tried to disconnect different interrupts and re-run - but there does not seem to be a guaranteed correlation between interrupts and seeing this error.  Is there a way to track down exactly which instruction is causing this error?  Do I have to decode the Disassembly window to figure it out? Is there an easier way?
Or am I not reserving the BRAM in the proper way in Vivado to ensure enough space for the program to run?
