Newbie zahidi
UART 16550 example with interupts
Does any one has a UART 16550 working example. If you change the uartlite to uart16550 in the base system builder it does not generate the correct files and the exaple in the SW directory seem not to work correclt either.
thanks,
Z
Re: UART 16550 example with interupts
Did you try this?
http://www.opencores.org/project,uart16550
( didn't examine it, but you may not know this)
Historian
Historian
zahidi wrote:
thanks,
Z
Clean the project, and regenerate all of the libraries/etc.
Hey
I have question about the pinout interrupt of the uart 16550 I added the ip of opencores in my design I used the board zedboard zynq. When I tested the ip with my c programme the pinout int is high when I write fcr <--- 1 when I did a reset
fcr <--- 4 or fcr <---- 2 the pinout int was'nt low. Maybe I forget programm a register do you have a problem similar or a example in c language.
Best regards.
