Observer lmeyerovich
UART 16550 v2.0 In FIFO mode receives interrupt on every byte
I am running AXI UART 16550 implemented for ZCU102 evaluation board (UltraScale+).
Only Rx interrupt is enabled (Tx is disabled). FIFO is configured for any thrigger level other than 1, I have tried 14, 8, 4. I have cretated an example to count number of interrupt received and figured out that an interrupt is triggered for every incoming byte
What am I doing wrong?
Here is my initialization and IRQ function:
    /* Set word length, stop bits, and parity based off configuration */
    *REG_PTR(vaddr, LCR) |= (LCR_WLS(uart_conf->word_len) | (uart_conf->stop_bits * LCR_STB));
    if (uart_conf->parity != UART16650_PARITY_NO) {
        *REG_PTR(vaddr, LCR) |= (LCR_PEN | (uart_conf->parity * LCR_EPS));
    *REG_PTR(vaddr, IIR);  // clear Tx interrupt
    *REG_PTR(vaddr, FCR) = FCR_FIFOEN | FCR_RCFR | FCR_XMFR | FCR_RFTL(3);
    *REG_PTR(m_vaddr, IER) = (IER_EFBFI | IER_ELSI);
And interrupt processing (this function gets called from IRQ handler:
int axi_process_interrupt(int uartIndex, char *pbuf, int *nbytes)
                unsigned int vLSR;
                ps_chardevice_t* d = uarts[uartIndex].dev;
                unsigned int vIIR = *REG_PTR(d->vaddr, IIR);
                if ((vIIR & INTERRUPT_PENDING_MASK) == 0)
                {// interrupt pending
                                unsigned int iir = (vIIR & INTERRUPT_ID_MASK) >> 1;
                                switch (iir)
                                case uart16550_RECEIVER_LINE_STATUS:
                                                // clear interrupt
                                                vLSR = *REG_PTR(d->vaddr, LSR);
                                                if ((vLSR & 0x80) != 0)
                                                return uart16550_RECEIVER_LINE_STATUS;
                                                break;
                                case uart16550_CHARACTER_TIMEOUT:
                                case uart16550_DATA_AVAILABLE:
                                                // read date from FIFO. This interrupt is cleared when the Receiver FIFO drops below the trigger level.
                                                *nbytes = 0;
                                                while (true)
        unsigned int vLSR = *REG_PTR(d->vaddr, LSR);
        if ((vLSR & 0x2) != 0)
        return -1; // Overrun Error.
        if ((vLSR & 0x1) == 0)
        break;
        // data is available
        pbuf[*nbytes] = (*REG_PTR(d->vaddr, RBR)) & 0xFF;
        (*nbytes)++;
                                                return uart16550_DATA_AVAILABLE;
                                                break;
                                case uart16550_TX_IS_EMPTY:
                                                return uart16550_TX_IS_EMPTY;
                                                break;
                return -2;
