UART Problem: Can Send , But Can not Receive
Based on the coding below , I can not receive anything from the hyperterminal. How can I rectify the problem , so that I can receive data from the hyperterminal and display it back to the hyperterminal? I tried to debug , but there is no value assign to t . If the coding is wrong, should I use array.
#include "xparameters.h"
#include "xuartlite.h"
#define UART_BASEADDR XPAR_UARTLITE_0_BASEADDR
#define ESCAPE 0x1b
static void myprintf (char *s)
  char t;
  while (*s)
   XUartLite_SendByte (UART_BASEADDR ,*s ); // Able to send to Hyperterminal
   s++;
 do
   /*Problem is here. It should receive data from hyperterminal and display it back.
   But it does not work.How should I rectify it? */
     t = XUartLite_RecvByte(UART_BASEADDR); //Receive
     XUartLite_SendByte (UART_BASEADDR , t ); //Send
 } while (t != ESCAPE);
int main()
 myprintf("Good morning");
 return 0;
This is the UCF , which automatically generated by using XPS 9.2
Net sys_clk_pin LOC=AE14;
Net sys_clk_pin IOSTANDARD = LVCMOS33;
Net sys_rst_pin LOC=D6;
Net sys_rst_pin PULLUP;
## System level constraints
Net sys_clk_pin TNM_NET = sys_clk_pin;
TIMESPEC TS_sys_clk_pin = PERIOD sys_clk_pin 10000 ps;
Net sys_rst_pin TIG;
## IO Devices constraints
#### Module RS232_Uart constraints
Net fpga_0_RS232_Uart_RX_pin LOC=W2;
Net fpga_0_RS232_Uart_RX_pin IOSTANDARD = LVCMOS33;
Net fpga_0_RS232_Uart_TX_pin LOC=W1;
Net fpga_0_RS232_Uart_TX_pin IOSTANDARD = LVCMOS33;
Re: UART Problem: Can Send , But Can not Receive
 Ok, Rule #1 with forums:
Do NOT re-post the same thing over-and-over-and-over again. It will not get people's attention. It will get their UN-attention. They will skip over it and never answer any of your questions in the future.
I'll reply to the 'original' post of yours to which  I first replied.
Mod's: can we get a lock/delete?
Excellent advice...
Another bad idea would be have a friend create an account and post the exact same questions again. Though I can't find these now, so maybe you realized this was a bad idea and had them deleted.
bt
