USB 3.0 ZCU102 Ubuntu
(Sorry for posting this again, I've posted it in the wrong location before)
Hello!
I've got a problem with connecting a USB 3.0 camera to the ZCU102 running Ubuntu.
The camera seems to be only detected as USB 2.0 in Ubuntu. On my windows machine it works fine with USB 3.0.
I thought the reason may be the adapter because of this tread: https://forums.xilinx.com/t5/Evaluation-Boards/ZCU102-ES2-USB-3-0-Host-mode/td-p/749487
But now I've tested two micro USB to USB 3.0 adapter, both with the same result. (For example this one: amazon usb adapter)
I've configured the jumpers according to this post: https://www.xilinx.com/support/answers/69164.html
This is my jumper configuration:
This is the output of lsusb under Ubuntu:
How can I confugure the board to use Bus 002 (which is 3.0) for my camera?
This is the output of usb-devices:
Thanks for any help!
Re: USB 3.0 ZCU102 Ubuntu
The only reason is the USB adapter,are you using the ZCU102 production board?
https://www.xilinx.com/support/answers/69151.html
Thanks for your answer!
In the link it is recommanded to use the adapter from Whizz Systems, but I've problems with purchasing exactly this adapter in Europe.
Could you also provide a link with another adapter that sould work?
I don’t know how to purchase it. it’s shipped with the production ZCU102 board.
USB 3.0 is notoriously picky/finicky about cabling. USB 2.0 and USB 1.1 are so low speed that it’s not difficult to hit the line rates since it’s just D+/D-. With USB 3.0 the wiring of the transceiver wires inside the cable (plus the grounding) can make cables the “critical path” of a USB 3.0 connection. In short, don’t use cheap cables. Spend the time to locate quality cables and spend the money on them.
Maybe it’s also a HW/SW setting issue, since I don’t know your setting, please check other USB3 device like Mass storage
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841729/Zynq+Ultrascale+MPSOC+Linux+USB+device+driver
Xilinx provides the pre-build bootimage in PetaLinux ZCU102 BSP. Just try it to check if USB3.0 can be connected with your adapter.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Thanks again!
I've tested with the prebuild image and another USB 3.0 device and a new USB 3.0 adapter, but the problem remains.
What I'm wondering about is that lsusb lists the device at BUS 1 which is declared as "2.0 root hub", while BUS 2 is declared as "3.0 root hub". (See the image in my first post)
From my understanding there are two USB conrollers on PS side, one for 3.0 and one for 2.0 but both are connected to the same output and you can change the configuration with jumpers. Is this correct?
Maybe my jumper configuration is somehow wrong, eventhough I think I've set them according to this link: https://www.xilinx.com/support/answers/69164.html
Do you think there could be another issue as the USB adapter?
