USB Embedded Processor IP
hi can anyone help me I want to use the zynq 7020 for a project but i am unable to use all my ports
i am using the free software
i am unable to use bank 501
is there a lock on the pins as it saying read only
i like to use the embedded processors but i am finding
a lot of my port pin are used for FIXED_IO
or is it because I am using the free web software
Re: USB Embedded Processor IP
The only limitations when using the free WebPACK edition of Vivado are that it's device locked and not for commercial use, so there should be no restrictions for your project.
In order to use the embedded processors you need to create a block design and add a processing system to it. Then you can map PS to the IO ports. There should be a lot of tutorials on how to do this.
Bank 501 is used by PS, those are fixed IOs. You can only configure them. You can't custom use them from HDL
@recyclehere wrote:
Webpack is not restricted to non-commercial use.
https://forums.xilinx.com/t5/General-Technical-Discussion/WebPack-and-commercial-use/m-p/50006#M2343
Joe Samson
Thanks for pointing out. I didn't know that.
