Visitor ltmin
Ubuntu Desktop on ZCU102
I have troubles running Ubuntu on my ZCU102 board (rev 1.0)
Based on the wiki page below, I can successfully build & see the boot log from the UART console
But the problem is that it cannot display GUI on DP monitor with error message: [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
It seems that the files of the wiki page is only for the rev D board and there's no further notice when to update the files
Please help me to sort things out
http://www.wiki.xilinx.com/Zynq+UltraScale%EF%BC%8B+MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.6.0-xilinx (ltmin@cmapcie) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #1 SMP Sun Apr 9 22:42:19 KST 2017
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff44000 s45824 r8192 d32000 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1034240
[    0.000000] Kernel command line: earlycon=cdns,mmio,0xFF000000,115200n8 root=/dev/mmcblk0p2 rw rootwait cma=256M
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0x6bfff000-0x6ffff000] (64MB) mapped at [ffffffc06bfff000-ffffffc06fffefff]
[    0.000000] Memory: 3781232K/4194304K available (9032K kernel code, 1029K rwdata, 3100K rodata, 808K init, 380K bss, 150928K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdffff0000   (   247 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008950000   (  9024 KB)
[    0.000000]     .rodata : 0xffffff8008950000 - 0xffffff8008c5b000   (  3116 KB)
[    0.000000]       .init : 0xffffff8008c5b000 - 0xffffff8008d25000   (   808 KB)
[    0.000000]       .data : 0xffffff8008d25000 - 0xffffff8008e26600   (  1030 KB)
[    0.000000]     vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000   (     7 GB maximum)
[    0.000000]               0xffffffbe00000000 - 0xffffffbe1dc00000   (   476 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc880000000   ( 34816 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 100.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[    0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008408] Console: colour dummy device 80x25
[    0.012664] console [tty0] enabled
[    0.016028] bootconsole [cdns0] disabled
PMUFW: PmGetApiVersion: version 0.2
PMUFW: PmRequestWakeup: (NODE_APU_1, REQUEST_ACK_BLOCKING)
PMUFW: PmProcTrSleepToActive: SLEEP->ACTIVE NODE_APU_1
PMUFW: PmRequestWakeup: (NODE_APU_2, REQUEST_ACK_BLOCKING)
PMUFW: PmProcTrSleepToActive: SLEEP->ACTIVE NODE_APU_2
PMUFW: PmRequestWakeup: (NODE_APU_3, REQUEST_ACK_BLOCKING)
PMUFW: PmProcTrSleepToActive: SLEEP->ACTIVE NODE_APU_3
[    0.019937] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[    0.019954] pid_max: default: 32768 minimum: 301
[    0.020073] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020086] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020563] ftrace: allocating 29743 entries in 117 pages
[    0.061334] ASID allocator initialised with 65536 entries
[    0.061933] zynqmp_plat_init Power management API v0.2
[    0.062011] EFI services will not be available.
[    0.069549] Detected VIPT I-cache on CPU1
[    0.069585] CPU1: Booted secondary processor [410fd034]
[    0.079578] Detected VIPT I-cache on CPU2
[    0.079599] CPU2: Booted secondary processor [410fd034]
[    0.089613] Detected VIPT I-cache on CPU3
[    0.089633] CPU3: Booted secondary processor [410fd034]
[    0.089674] Brought up 4 CPUs
[    0.089714] SMP: Total of 4 processors activated.
[    0.089727] CPU: All CPU(s) started at EL2
[    0.089746] alternatives: patching kernel code
[    0.090537] devtmpfs: initialized
[    0.095154] DMI not present or invalid.
[    0.095248] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.102523] xor: measuring software checksum speed
[    0.141714]    8regs     :  2165.000 MB/sec
[    0.181750]    8regs_prefetch:  1924.000 MB/sec
[    0.221786]    32regs    :  2397.000 MB/sec
[    0.261822]    32regs_prefetch:  1987.000 MB/sec
[    0.261836] xor: using function: 32regs (2397.000 MB/sec)
[    0.262502] NET: Registered protocol family 16
[    0.263087] vdso: 2 pages (1 code @ ffffff8008956000, 1 data @ ffffff8008d2c000)
[    0.263128] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.263702] DMA: preallocated 256 KiB pool for atomic allocations
[    0.264798] ARM CCI_400_r1 PMU driver probed
[    0.286181] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.353975] raid6: int64x1  gen()   412 MB/s
[    0.422058] raid6: int64x1  xor()   423 MB/s
[    0.490178] raid6: int64x2  gen()   617 MB/s
[    0.558208] raid6: int64x2  xor()   549 MB/s
[    0.626338] raid6: int64x4  gen()   902 MB/s
[    0.694380] raid6: int64x4  xor()   679 MB/s
[    0.762459] raid6: int64x8  gen()  1051 MB/s
[    0.830515] raid6: int64x8  xor()   681 MB/s
[    0.898614] raid6: neonx1   gen()   669 MB/s
[    0.966687] raid6: neonx1   xor()   692 MB/s
[    1.034764] raid6: neonx2   gen()  1037 MB/s
[    1.102819] raid6: neonx2   xor()   921 MB/s
[    1.170904] raid6: neonx4   gen()  1374 MB/s
[    1.238952] raid6: neonx4   xor()  1072 MB/s
[    1.307043] raid6: neonx8   gen()  1552 MB/s
[    1.375113] raid6: neonx8   xor()  1128 MB/s
[    1.375127] raid6: using algorithm neonx8 gen() 1552 MB/s
[    1.375141] raid6: .... xor() 1128 MB/s, rmw enabled
[    1.375154] raid6: using intx1 recovery algorithm
[    1.376087] arm-smmu fd800000.smmu: probing hardware configuration...
[    1.376105] arm-smmu fd800000.smmu: SMMUv2 with:
[    1.376120] arm-smmu fd800000.smmu: 	stage 1 translation
[    1.376134] arm-smmu fd800000.smmu: 	stage 2 translation
[    1.376149] arm-smmu fd800000.smmu: 	nested translation
[    1.376168] arm-smmu fd800000.smmu: 	stream matching with 48 register groups, mask 0x7fff
[    1.376191] arm-smmu fd800000.smmu: 	16 context banks (0 stage-2 only)
[    1.376209] arm-smmu fd800000.smmu: 	Supported page sizes: 0x60211000
[    1.376225] arm-smmu fd800000.smmu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    1.376241] arm-smmu fd800000.smmu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    1.377350] arm-smmu fd800000.smmu: registered 26 master devices
[    1.377658] iommu: Adding device fd500000.dma to group 0
[    1.377691] iommu: Adding device fd510000.dma to group 1
[    1.377722] iommu: Adding device fd520000.dma to group 2
[    1.377755] iommu: Adding device fd530000.dma to group 3
[    1.377785] iommu: Adding device fd540000.dma to group 4
[    1.377816] iommu: Adding device fd550000.dma to group 5
[    1.377846] iommu: Adding device fd560000.dma to group 6
[    1.377877] iommu: Adding device fd570000.dma to group 7
[    1.377920] iommu: Adding device ffa80000.dma to group 8
[    1.377950] iommu: Adding device ffa90000.dma to group 9
[    1.377981] iommu: Adding device ffaa0000.dma to group 10
[    1.378014] iommu: Adding device ffab0000.dma to group 11
[    1.378045] iommu: Adding device ffac0000.dma to group 12
[    1.378075] iommu: Adding device ffad0000.dma to group 13
[    1.378105] iommu: Adding device ffae0000.dma to group 14
[    1.378136] iommu: Adding device ffaf0000.dma to group 15
[    1.378178] iommu: Adding device ff0e0000.ethernet to group 16
[    1.378253] iommu: Adding device ff0f0000.spi to group 17
[    1.378315] iommu: Adding device ff170000.sdhci to group 18
[    1.378378] iommu: Adding device amba:usb@fe200000 to group 19
[    1.378842] SCSI subsystem initialized
[    1.379070] usbcore: registered new interface driver usbfs
[    1.379134] usbcore: registered new interface driver hub
[    1.379183] usbcore: registered new device driver usb
[    1.379288] media: Linux media interface: v0.10
[    1.379331] Linux video capture interface: v2.00
[    1.379376] pps_core: LinuxPPS API ver. 1 registered
[    1.379391] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.379429] PTP clock support registered
[    1.379482] EDAC MC: Ver: 3.0.0
[    1.379703] dmi: Firmware registration failed.
[    1.379799] FPGA manager framework
[    1.379856] Advanced Linux Sound Architecture Driver Initialized.
[    1.380768] clocksource: Switched to clocksource arch_sys_counter
[    1.412463] VFS: Disk quotas dquot_6.6.0
[    1.412532] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.416666] NET: Registered protocol family 2
[    1.417079] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.417379] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.417914] TCP: Hash tables configured (established 32768 bind 32768)
[    1.417979] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.418076] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.418279] NET: Registered protocol family 1
[    1.418472] RPC: Registered named UNIX socket transport module.
[    1.418488] RPC: Registered udp transport module.
[    1.418501] RPC: Registered tcp transport module.
[    1.418514] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.418765] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.419483] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    1.419565] audit: initializing netlink subsys (disabled)
[    1.419597] audit: type=2000 audit(1.368:1): initialized
[    1.420085] workingset: timestamp_bits=60 max_order=20 bucket_order=0
[    1.420867] NFS: Registering the id_resolver key type
[    1.420902] Key type id_resolver registered
[    1.420915] Key type id_legacy registered
[    1.420940] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.420994] jffs2: version 2.2. (NAND) (SUMMARY)  짤 2001-2006 Red Hat, Inc.
[    1.426571] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.426602] io scheduler noop registered
[    1.426619] io scheduler deadline registered
[    1.426651] io scheduler cfq registered (default)
[    1.427577] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    1.427880] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.428010] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.428144] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.428277] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.428409] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.428544] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.428683] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.428849] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.428992] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.429127] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.429258] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.429391] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.429524] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.429654] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.429789] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.429920] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.430009] zynqmp_pm firmware: Power management API v0.2
[    1.430109] xenfs: not registering filesystem on non-xen platform
[    1.454322] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.455469] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 215, base_baud = 6250000) is a xuartps
[    2.556943] console [ttyPS0] enabled
[    2.560725] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 216, base_baud = 6250000) is a xuartps
[    2.569988] [drm] Initialized drm 1.1.0 20060810
[    2.574924] [drm] load() is defered & will be called again
[    2.580816] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
[    2.588707] Unable to detect cache hierarchy from DT for CPU 0
[    2.599234] brd: module loaded
[    2.605094] loop: module loaded
[    2.608925] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[    2.617828] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.628127] scsi host0: ahci-ceva
[    2.631581] scsi host1: ahci-ceva
[    2.634934] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 212
[    2.642869] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 212
[    2.651013] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.657830] zynqmp-qspi ff0f0000.spi: rx bus width not found
PMUFW: PmMmioRead: (NODE_APU) addr=0xFF180390, value=0x7
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180390, mask=0x7, value=0x7
[    2.680193] m25p80 spi0.0: found n25q512a, expected m25p80
[    2.762817] m25p80 spi0.0: n25q512a (131072 Kbytes)
[    2.773242] 4 ofpart partitions found on MTD device spi0.0
[    2.778692] Creating 4 MTD partitions on "spi0.0":
[    2.783470] 0x000000000000-0x000001e00000 : "boot"
[    2.788739] 0x000001e00000-0x000001e40000 : "bootenv"
[    2.794162] 0x000001e40000-0x000004240000 : "kernel"
[    2.799505] 0x000004240000-0x000008000000 : "spare"
[    2.806359] libphy: Fixed MDIO Bus: probed
[    2.810871] tun: Universal TUN/TAP device driver, 1.6
[    2.815856] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.822120] CAN device driver interface
[    2.826723] gpiod_set_value: invalid GPIO
[    2.831061] libphy: MACB_mii_bus: probed
[    2.836434] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[    2.846207] TI DP83867 ff0e0000.etherne:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.etherne:0c, irq=-1)
[    2.857893] usbcore: registered new interface driver asix
[    2.863271] usbcore: registered new interface driver ax88179_178a
[    2.869329] usbcore: registered new interface driver cdc_ether
[    2.875142] usbcore: registered new interface driver net1080
[    2.880792] usbcore: registered new interface driver cdc_subset
[    2.886687] usbcore: registered new interface driver zaurus
[    2.892267] usbcore: registered new interface driver cdc_ncm
[    2.898824] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.905519] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.910956] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.918883] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
[    2.927550] xhci-hcd xhci-hcd.0.auto: irq 220, io mem 0xfe200000
[    2.933634] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.940353] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.947560] usb usb1: Product: xHCI Host Controller
[    2.952413] usb usb1: Manufacturer: Linux 4.6.0-xilinx xhci-hcd
[    2.958316] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.961936] ata2: SATA link down (SStatus 0 SControl 330)
[    2.961970] ata1: SATA link down (SStatus 0 SControl 330)
[    2.974228] hub 1-0:1.0: USB hub found
[    2.977919] hub 1-0:1.0: 1 port detected
[    2.981928] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.987354] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    2.995036] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.003140] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    3.009855] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.017062] usb usb2: Product: xHCI Host Controller
[    3.021915] usb usb2: Manufacturer: Linux 4.6.0-xilinx xhci-hcd
[    3.027818] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.032923] hub 2-0:1.0: USB hub found
[    3.036611] hub 2-0:1.0: 1 port detected
[    3.040693] usbcore: registered new interface driver uas
[    3.046011] usbcore: registered new interface driver usb-storage
[    3.052191] mousedev: PS/2 mouse device common for all mice
[    3.058070] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    3.065274] i2c /dev entries driver
[    3.070730] pca953x 0-0020: interrupt support not compiled in
[    3.078165] pca953x 0-0021: interrupt support not compiled in
[    3.083898] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 206
[    3.090106] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 207
[    3.096885] i2c i2c-0: Added multiplexed i2c bus 2
[    3.102083] i2c i2c-0: Added multiplexed i2c bus 3
[    3.107512] i2c i2c-0: Added multiplexed i2c bus 4
[    3.112339] i2c i2c-0: Added multiplexed i2c bus 5
[    3.117060] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[    3.124829] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[    3.131468] i2c i2c-6: Failed to register i2c client 24c08 at 0x55 (-16)
[    3.138147] i2c i2c-6: of_i2c: Failure registering /amba/i2c@ff030000/i2cswitch@74/i2c@0/eeprom@55
[    3.147094] i2c i2c-6: Failed to register i2c client 24c08 at 0x56 (-16)
[    3.153765] i2c i2c-6: of_i2c: Failure registering /amba/i2c@ff030000/i2cswitch@74/i2c@0/eeprom@56
[    3.162718] i2c i2c-6: Failed to register i2c client 24c08 at 0x57 (-16)
[    3.169389] i2c i2c-6: of_i2c: Failure registering /amba/i2c@ff030000/i2cswitch@74/i2c@0/eeprom@57
[    3.178347] i2c i2c-1: Added multiplexed i2c bus 6
[    3.183273] i2c i2c-1: Added multiplexed i2c bus 7
[    3.188149] i2c i2c-1: Added multiplexed i2c bus 8
[    3.193025] i2c i2c-1: Added multiplexed i2c bus 9
[    3.197951] i2c i2c-1: Added multiplexed i2c bus 10
[    3.202864] i2c i2c-1: Added multiplexed i2c bus 11
[    3.207780] i2c i2c-1: Added multiplexed i2c bus 12
[    3.212690] i2c i2c-1: Added multiplexed i2c bus 13
[    3.217499] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[    3.225255] i2c i2c-1: Added multiplexed i2c bus 14
[    3.230172] i2c i2c-1: Added multiplexed i2c bus 15
[    3.235086] i2c i2c-1: Added multiplexed i2c bus 16
[    3.240231] i2c i2c-1: Added multiplexed i2c bus 17
[    3.245156] i2c i2c-1: Added multiplexed i2c bus 18
[    3.250079] i2c i2c-1: Added multiplexed i2c bus 19
[    3.254997] i2c i2c-1: Added multiplexed i2c bus 20
[    3.259917] i2c i2c-1: Added multiplexed i2c bus 21
[    3.264724] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[    3.273753] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.280383] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.287012] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.293639] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.300264] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.306889] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.308785] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[    3.319960] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.326584] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.333216] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.339843] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.346546] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[    3.353167] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.359792] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.366420] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.373046] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.379675] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.386304] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.392933] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[    3.399833] EDAC MC: ECC not enabled
[    3.403484] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[    3.412541] EDAC MC: bug in low-level driver: attempt to assign
[    3.412541]     duplicate dev_idx 0 in add_edac_dev_to_global_list()
[    3.424753] zynqmp-ocm-edac: probe of ff960000.memory-controller failed with error -1
[    3.432626] sdhci: Secure Digital Host Controller Interface driver
[    3.438734] sdhci: Copyright(c) Pierre Ossman
[    3.443071] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.456838] usb 1-1: New USB device found, idVendor=04f3, idProduct=0210
[    3.463484] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.470588] usb 1-1: Product: PS/2+USB Mouse
[    3.484777] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    3.492914] ledtrig-cpu: registered to indicate activity on CPUs
[    3.505086] input: PS/2+USB Mouse as /devices/platform/amba/amba:usb@fe200000/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:04F3:0210.0001/input/input0
[    3.520827] hid-generic 0003:04F3:0210.0001: input: USB HID v1.11 Mouse [PS/2+USB Mouse] on usb-xhci-hcd.0.auto-1/input0
[    3.531679] usbcore: registered new interface driver usbhid
[    3.537177] usbhid: USB HID core driver
[    3.542877] si570 8-005d: registered, current frequency 300000000 Hz
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180358, mask=0x40000, value=0x40000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x2000000, value=0x2000000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x1000000, value=0x1000000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0xFF0000, value=0x150000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180314, mask=0x2000000, value=0x0
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180318, mask=0x400000, value=0x400000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180318, mask=0x3F0000, value=0x50000
PMUFW: PmMmioWrite: (NODE_APU) addr=0xFF180358, mask=0x40000, value=0x0
[    3.562810] si570 9-005d: registered, current frequency 148500000 Hz
[    3.765838] mmc0: new high speed SDHC card at address aaaa
[    3.766065] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    3.781730]  mmcblk0: p1 p2
[    3.789678] fpga_manager fpga0: Xilinx ZynqMp FPGA Manager registered
[    3.796544] xilinx-dp-snd-pcm amba:dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[    3.804160] xilinx-dp-snd-pcm amba:dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[    3.811888] xilinx-dp-snd-codec amba:dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[    3.820301] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.830418] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.840784] xilinx-dp-snd-card amba:dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.848625] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    3.856451] Initializing XFRM netlink socket
[    3.860716] NET: Registered protocol family 10
[    3.865536] sit: IPv6 over IPv4 tunneling driver
[    3.870464] NET: Registered protocol family 17
[    3.874843] NET: Registered protocol family 15
[    3.879258] can: controller area network core (rev 20120528 abi 9)
[    3.885445] NET: Registered protocol family 29
[    3.889857] can: raw protocol (rev 20120528)
[    3.894101] can: broadcast manager protocol (rev 20120528 t)
[    3.899746] can: netlink gateway (rev 20130117) max_hops=1
[    3.905397] 9pnet: Installing 9P2000 support
[    3.909611] Key type dns_resolver registered
[    3.914284] registered taskstats version 1
[    3.918740] Btrfs loaded
[    3.921923] [drm] load() is defered & will be called again
[    3.927936] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[    3.935916] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
[    3.942029] xilinx-drm-dp fd4a0000.dp: Display Port, version 1.0200 (tx)
[    3.949252] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.955802] [drm] No driver support for vblank timestamp query.
[    3.962827] xilinx-drm amba:xilinx_drm: No connectors reported connected with modes
[    3.970417] [drm] Cannot find any crtc or sizes - going 1024x768
[    3.982583] Console: switching to colour frame buffer device 128x48
[    3.993899] xilinx-drm amba:xilinx_drm: fb0:  frame buffer device
[    4.008776] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
[    4.015390] rtc_zynqmp ffa60000.rtc: setting system clock to 1987-02-16 10:15:13 UTC (540468913)
[    4.024635] ALSA device list:
[    4.027552]   #0: DisplayPort monitor
[    4.035449] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[    6.044988] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
[    6.050288] EXT4-fs (mmcblk0p2): recovery complete
[    6.071842] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    6.079969] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    6.092463] devtmpfs: mounted
[    6.095624] Freeing unused kernel memory: 808K (ffffff8008c5b000 - ffffff8008d25000)
Mount failed for selinuxfs on /sys/fs/selinux:  No such file or directory
[    6.582878] init: ureadahead main process (1615) terminated with status 5with status 1
 * Starting Mount filesystems on boot                                    [ OK ]
 * Starting Signal sysvinit that the rootfs is mounted                   [ OK ]
 * Starting Populate /dev filesystem                                     [ OK ]
 * Stopping Populate /dev filesystem                                     [ OK ]
 * Starting mount available cgroup filesystems                           [ OK ]
 * Starting Clean /tmp directory                                         [ OK ]
 * Starting Populate and link to /run filesystem                         [ OK ]
 * Stopping Populate and link to /run filesystem                         [ OK ]
 * Stopping Track if upstart is running in a container                   [ OK ]
 * Stopping Clean /tmp directory                                         [ OK ]
 * Starting Initialize or finalize resolvconf                            [ OK ]
 * Starting set console keymap                                           [ OK ]
 * Starting Signal sysvinit that virtual filesystems are mounted         [ OK ]
 * Starting Bridge udev events into upstart                              [ OK ]
 * Stopping set console keymap                                           [ OK ]
 * Starting device node and kernel event manager                         [ OK ]
 * Starting Signal sysvinit that local filesystems are mounted           [ OK ]
 * Starting load modules from /etc/modules                               [ OK ]
 * Starting cold plug devices                                            [ OK ]
 * Starting log initial device creation                                  [ OK ]
 * Starting Signal sysvinit that remote filesystems are mounted          [ OK ]
 * Stopping load modules from /etc/modules                               [ OK ]
 * Starting flush early job output to logs                               [ OK ]
 * Stopping Mount filesystems on boot                                    [ OK ]
 * Stopping flush early job output to logs                               [ OK ]
 * Starting NFSv4 id <-> name mapper                                     [ OK ]
 * Stopping rpcsec_gss daemon                                            [ OK ]
 * Starting D-Bus system message bus                                     [ OK ]
 * Starting system logging daemon                                        [ OK ]
 * Starting set console font                                             [ OK ]
 * Starting SystemD login management service                             [ OK ]
 * Stopping set console font                                             [ OK ]
 * Starting userspace bootsplash                                         [ OK ]
 * Starting mDNS/DNS-SD daemon                                           [ OK ]
 * Stopping userspace bootsplash                                         [ OK ]
 * Starting Send an event to indicate plymouth is up                     [ OK ]
 * Starting Reload cups, upon starting avahi-daemon to make sure remote q[ OK ]are populated
 * Stopping Send an event to indicate plymouth is up                     [ OK ]
 * Stopping Reload cups, upon starting avahi-daemon to make sure remote q[ OK ]are populated
 * Starting bluetooth daemon                                             [ OK ]
 * Stopping cold plug devices                                            [ OK ]
 * Stopping log initial device creation                                  [ OK ]
 * Starting configure network device security                            [ OK ]
 * Starting save udev log and update rules                               [ OK ]
 * Stopping save udev log and update rules                               [ OK ]
 * Starting configure network device                                     [ OK ]
 * Starting System V initialisation compatibility                        [ OK ]
 * Starting modem connection manager                                     [ OK ]
 * Starting configure virtual network devices                            [ OK ]
 * Setting up X socket directories...                                    [ OK ]
 * Starting Mount network filesystems                                    [ OK ]
 * Starting Upstart job to start rpcbind on boot only                    [ OK ]
 * Starting Failsafe Boot Delay                                          [ OK ]
 * Stopping Upstart job to start rpcbind on boot only                    [ OK ]
 * Starting network connection manager                                   [ OK ]
 * Stopping System V initialisation compatibility                        [ OK ]
SpamAssassin Mail Filter Daemon: disabled, see /etc/default/spamassassin
 * speech-dispatcher disabled; edit /etc/default/speech-dispatcher
 * Starting System V runlevel compatibility                              [ OK ]
 * Starting regular background program processing daemon                 [ OK ]
 * Starting xinetd daemon                                                [ OK ]
 * Starting anac(h)ronistic cron                                         [ OK ]
 * Starting save kernel messages                                         [ OK ]
 * Starting OpenSSH server                                               [ OK ]
 * Stopping save kernel messages                                         [ OK ]
 * Not running within Xen or no compatible utils
 * Starting RPC portmapper replacement                                   [ OK ]
 * Stopping Mount network filesystems                                    [ OK ]
 * Starting crash report submission daemon                               [ OK ]
 * No usable Xen toolstack selected
 * Starting automatic crash report generation                            [ OK ]
 * Starting NTP server ntpd                                              [ OK ]
 * Starting cups-browsed - Bonjour remote printer browsing daemon        [ OK ]
saned disabled; edit /etc/default/saned
 * Starting NSM status monitor                                           [ OK ]
 * Stopping Restore Sound Card State                                     [ OK ]
: not founddesktop.sh: 3: ./root/run_desktop.sh:
sleep: invalid time interval '1\r'
Try 'sleep --help' for more information.
: not founddesktop.sh: 5: ./root/run_desktop.sh:
: not founddesktop.sh: 7: ./root/run_desktop.sh:
: not founddesktop.sh: 9: ./root/run_desktop.sh:
: not founddesktop.sh: 10: ./root/run_desktop.sh:
: not founddesktop.sh: 11: ./root/run_desktop.sh:
 * Stopping System V runlevel compatibility                              [ OK ]
Ubuntu 14.04.3 LTS zcu102 ttyPS0
zcu102 login:
X.Org X Server 1.15.1
Release Date: 2014-04-13
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-55351-g1c40ba8-dirty aarch64
Current Operating System: Linux zcu102 4.6.0-xilinx #1 SMP Sun Apr 9 22:42:19 KST 2017 aarch64
Build Date: 19 May 2016  12:30:16AM
Current version of pixman: 0.30.2
	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 16 10:15:20 1987
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
 * Starting bluetooth daemon                                             [fail]
 * Stopping bluetooth daemon                                             [ OK ]
 * Starting Bridge file events into upstart                              [ OK ]
 * Starting Bridge socket events into upstart                            [ OK ]
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
[   11.789066] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
 * Starting libvirt daemon                                               [ OK ]
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Compat map for group 2 redefined
>                   Using new definition
> Warning:          Compat map for group 3 redefined
> Warning:          Compat map for group 4 redefined
Errors from xkbcomp are not fatal to the X server
(nautilus:3513): Gtk-WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
 * Stopping LightDM Display Manager                                      [ OK ]
(nautilus:3513): IBUS-WARNING **: Unable to connect to ibus: Could not connect: Connection refused
[   24.046079] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
Nautilus-Share-Message: Called "net usershare info" but it failed: 'net usershare' returned error 255: net usershare: cannot open usershare directory /var/lib/samba/usershares. Error No such file or directory
Please ask your system administrator to enable user sharing.
Waiting for network configuration...
[   34.061986] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
 * Starting CUPS printing spooler/server                                 [ OK ]
[   44.077971] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
[   54.093988] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
[   64.109979] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
Waiting up to 60 more seconds for network configuration...
[   74.125973] [drm:xilinx_drm_dp_train] *ERROR* failed to set lane count
Re: Ubuntu Desktop on ZCU102
I've seen this before and can't quite remember the fix but here's a couple of tips:
There's a device tree patch relating to displayport and PL transceiver lanes and phys, if this is your own build make sure that's in.
Try different monitors, cables, and powering everything off and trying again.  With my zcu102 I have one particular monitor which only works once after power on then must be reset...
