Newbie mikedeeds
Ultrascale+ PS SPI Master
I can't figure out how to enable the PS SPI Master pins in the Ultrascale+.
When I enable SPI0 or SPI1 and select a set of MIO pins, I only see si and so pins assigned.  I should see mi and mo pins when SPI is used as a SPI Master.  Is there somewhere that I need to enable the SPI peripheral as a master?
Here is the Vivado setup page:
Thank you!
Re: Ultrascale+ PS SPI Master
Hi @mikedeeds,
Here in particular Vivado version PCW, the naming conventions is such that the so is MISO and si is MOSI lines.
The master is enabled.
Praveen
Hi @mikedeeds,
Praveen
Newbie mikedeeds
Thank you! This answers my question.
