Unexpected error while launching program: Error while running ps7_init method. Cannot write to target Cannot access JTAG-DP: invalid ACK value (0x00, expected=0x02) Error Address = 0xf8000778
HI,
not able to debug the application code for arm, but able to program fpga from "program FPGA " option in xilinix tools, why is this problem occurring. Previously my board used to work properly.
I am using zed board
Please help me to sort out this issue. I am struggling from 7 days, please help me....................
Re: Unexpected error while launching program: Error while running ps7_init method. Cannot write to target Cannot access JTAG-DP: invalid ACK value (0x00, expected=0x02) Error Address = 0xf8000778
Looks like you are executing the fsbl in SDK?
There are two ways to program the ps; using the ps7_init.tcl in the debugger, or via the ps7_init.c/h in the fsbl.
The fsbl is generally used when programming via SD card or QSPI.
Does a hello world application work?
Also, in your fsbl debug  config, try uncheck the ps7_init as this would be done in the fsbl anyway. However, as I said about fsbl from SDK doesn't make sense
Hello World program is working with QSPI mode,
but not able to program through the debugger mode. issue(Cannot access JTAG-DP: invalid ACK value (0x00, expected=0x02) Error Address = 0xf8000778 )
Hi nagavenkat@ecsonweb.com ,
Can you check the boot mode and ensure that it is in JTAG mode? Are youusing GDB or system debugger?
If this idea doesnt work, please make use of ps7_inti.tcl/.c file generated from latest version of SDK to rule out issue in ps7_init.
Praveen
