Unexpected error while launching program. java.lang.RuntimeException: Error while running ps7_init method.
Unexpected error while launching program. java.lang.RuntimeException: Error while running ps7_init method. Cannot write to target Cannot access JTAG-DP: invalid ACK value (0x07, expected=0x02) Error Address = 0xf800601c at com.xilinx.sdk.targetmanager.internal.TM.run_ps7_init(Unknown Source) at com.xilinx.sdk.targetmanager.internal.TM.runPs7Init(Unknown Source)
Scholar sampatd
Re: Unexpected error while launching program. java.lang.RuntimeException: Error while running ps7_init method.
Which version of the tool are you using?
Can you program the fpga using XMD?
Please check if this thread helps.
http://forums.xilinx.com/t5/Embedded-Processor-System-Design/Problems-getting-a-new-Zynq-board-up-and-running/td-p/364059
Thanks,Vijay
Hi @wandtdk
Did that helped?
Thanks,Vijay
