Visitor bit_slicer
Unnecessary float casting described in the MicroBlaze reference manual
While reading through the MicroBlaze Reference Manual I ran across an alarming entry (UG984 v2018.2 page 93):
"While conversions between floating point and integer formats are supported in hardware by the FPU, when C_USE_FPU is set to 2 (Extended), it is still best to avoid them when possible."
No further explanation is given.  Why is it best to avoid them???  When is it ok or not ok to use a hard cast?  Is there any instance where a hard cast will yield an erroneous result?  An example is given where a hard cast is in a loop which suggests it's a performance issue, but the wording isn't all that clear.
It's a bit like putting the text "Airbags may fail" somewhere in a car owners user manual, and leaving it at that.
Tags (3)
Re: Unnecessary float casting described in the MicroBlaze reference manual
The convention of avoiding unnecesary casting isn't specific to the MicroBlaze, but rather a general programming guideline. When you perform an explicit type cast, you are essentially telling the compiler "I know what I'm doing so stop checking". In other words, explicit type casting overrides compiler functionality and can be dangerous if used incorrectly. But again, this is true for all programming applications and not just the MicroBlaze.
Here are some relevant resources:
https://developerinsider.co/type-casting-c-programming/
https://stackoverflow.com/questions/1942159/need-some-clarification-regarding-casting-in-c
https://stackoverflow.com/questions/4167304/why-should-casting-be-avoided
Hope this helps!
Hope this helps!
