Observer adnan86
Using SDK instead Petalinux
I'm working on using Ethernet through SFP port for zc706 board and Vivado 2018.3. I used XAPP1082 document also using this link: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841633/Zynq+PL+Ethernet
Now, after fixing some errors, I create my bitstream. But to create the final step the link above used Petalinux. After fixing most error in Petalinux I can't build all images(2.4.1.6 section on the link above) Because task " do_complie " failed without seeing an error.
I wonder is there any document that explains such a project using SDK instead of Petalinux?
Also, a document built an Ethernet project through SFP that explained from scratch?
Thanks in advance.
Re: Using SDK instead Petalinux
If you are looking for the steps to create and debug a linux application in SDK, then the wiki below will show you the steps:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/70254659/Creating+Linux+application+targeting+the+RFDC+driver+in+SDK+2018.3
This is for the zcu111 board, but the same steps should help for other boards
Observer adnan86
Thanks, I will work on it to see finally I can run my project.
