Using XGpio to interface from MicroBlaze to PL
I am currently working on a design that copies data from MicroBlaze to PL DDR4 via AXI-DMA. After the copying is completely done, I want to flag that the DDR4 can now be read on PL side. To do this, I opted to connect an AXI-GPIO as output, which should mean I can write data to the GPIO and then use the GPIO in PL as flags. To do this, I connected the GPIO in block design to be a slave to the MicroBlaze, which seems fine as the address editor shows the memory range of the GPIO at 0x4000000 to 0x4000FFFF. I made the output of the GPIO to be external, and then port map this to a signal, which in turn is used in flow control etc.
My method for testing this is in my MicroBlaze code, I insert a breakpoint before the flag writes, then in an ILA core, I use the flag on PL side as a trigger. I program in debug mode, then idle the ILA to wait for trigger. I go back to SDK and resume the code, but the trigger is never asserted.
I have never used AXI GPIO before so I'm not sure if I have the process correct, but it seems straightforward. However, there is no flag signal so I must have gone wrong somewhere:
Here is the code that should be writing to the GPIO from PS side:
xil_printf("Initialising AXI-GPIO flags\n");
Status = XGpio_Initialize(&Gpio, GPIO_EXAMPLE_DEVICE_ID);
if (Status != XST_SUCCESS) {
xil_printf("Gpio Initialization Failed\r\n");
return XST_FAILURE;
xil_printf("GPIO base address is: %x\n", Gpio.BaseAddress);
xil_printf("GPIO isReady: %x\n", Gpio.IsReady);
xil_printf("GPIO dualChannel: %x\n", Gpio.IsDual);
xil_printf("GPIO interrupt ready: %x\n", Gpio.InterruptPresent);
xil_printf("GPIO direction is: %x\n", XGpio_GetDataDirection(&Gpio,1));
// set all data to be output, on channel 1
XGpio_SetDataDirection(&Gpio, 1, 0x00000000);
// write flags to all be high
xil_printf("GPIO flags set");
XGpio_DiscreteWrite(&Gpio, 1, 0xFFFFFFFF);
Here is the UART output showing that the GPIO has been initialized with correct addresses etc:
--- Entering main() ---
Info: DMA simple transfer started
Info: DMA simple transfer done
DMA transfer to DDR4 complete
GPIO base address is: 40000000
GPIO isReady: 11111111
GPIO dualChannel: 0
GPIO interrupt ready: 0
GPIO direction is: 0
GPIO flags set
And the base address matches
And here is the BD, where GPIO can be seen to be a slave of MicroBlaze:
Thanks for your time.
--- Estimated Development time: 2*Pi*(planned completion date) ---
Tags (3)
Re: Using XGpio to interface from MicroBlaze to PL
Yes, changing the AXI IP block to be Interconnect instead of Smartconnect fixed the issue.
Originally I had smartconnect as the AXI master and GPIO block as the slave, I changed this to have AXI interconnect as the master and it works now. I guess for connecting to peripherals it might be best to try regular interconnect first.
Your GPIO only has one channel; I believe that should be channel 0, not channel 1.
For example:
XGpio_SetDataDirection(&Gpio, 0, 0x00000000);
XGpio_DiscreteWrite(&Gpio, 0, 0xFFFFFFFF);
Joe Samson
Hi Joe - I will check that asap and come back to kudo and solved if it works. Thanks heaps
Hi @josephsamson
I tried channel = 0 like you suggested, but that makes my MicroBlaze program hang indefinitely. I know why though: The debugger shows that in assembly it hangs on:
00005bac:   bnei          r3 , 0            ; addr=0x00005bac: Xil_Assert + 0x0000003c
And the definition of XGpio_DiscreteWrite shows that for false conditions, the program will wait infinitely due to AssertWait:
void XGpio_DiscreteWrite(XGpio * InstancePtr, unsigned Channel, u32 Data)
Xil_AssertVoid(InstancePtr != NULL);
Xil_AssertVoid(InstancePtr->IsReady == XIL_COMPONENT_IS_READY);
Xil_AssertVoid((Channel == 1) ||
((Channel == 2) && (InstancePtr->IsDual == TRUE)));
XGpio_WriteReg(InstancePtr->BaseAddress,
((Channel - 1) * XGPIO_CHAN_OFFSET) + XGPIO_DATA_OFFSET,
Data);
The third assert indicates that if there is one channel, it must be equal to channel 1 (or channel 2 in the case that there are two)
So I think I was originally correct in writing Channel = 1. I'm going to continue to try and debug, thanks for the suggestion anyway, I thought the channel was the most logical thing that could be going wrong...
Update: Someone with much more experience than me suggested using peripheral interconnect instead of AXI Smartconnect to drive the AXI GPIO. Now the bus values actually change, although I haven't verified if the data is correct yet.
