Observer chandu_sri
Using Zynq APSOC and kintex FPGA together in a design
Hi there,
I want implement my project using Zynq 7045 APSOC and Kintex fpga together in one project. Is this possible? if yes can someone guide me how to implement such designs.
Thanks in advance,
Chandusri.
Scholar u4223374
Re: Using Zynq APSOC and kintex FPGA together in a design
It's definitely possible, but wouldn't it be easier to just use a bigger Zynq device and leave out the Kintex?
Implementing a dual-chip system should be easy. Design a board with both chips, connect them with an interface of your choice (SPI is a particularly straightforward interface to do on an FPGA since it's essentially just a shift register), then include a suitable IP in each project to use that interface. Problem solved.
Teacher muzaffer
yes, this is certainly possible. I have worked on a design with a 7010 next to a very large virtex7. All you need to do is to connect some wires between the two chips and add AXI chip2chip; voila you have an integrated system (you size the wires between the two chips according to your bandwidth needs).
Observer chandu_sri
@muzaffer
Thanks for the info i will get back to you if i need any further help. if possible can you attach your block design or any related files...that could be of great help to me.
Chandusri
Observer chandu_sri
Thanks for the info i will get back to you if i need any further help. if possible can you attach any related block design or files...that could be of great help to me
Chandusri
