Visitor daveylib
Validating project failure
Hey guys!
My development board is Z-turn Kit MYS-7Z020-C.
I use Vivado 2014.4 on 64-bit Ubuntu 14.04 LTS.
I run `mys-xc7z020-arm-hdmi-xylon` project from CD disc from manufacturer.
The problem is that I got errors when I try to validate block design.
I use pure project and don't edit it.
After validate failure I can’t generate a bitstream.
When I use pure project and don’t try validating block design, then I can generate a bitstream.
In attachments I send you photos of the errors.
How can I solve my problems?
Excuse my English.
Sincerely,
Dawid Liberda
Visitor daveylib
Re: Validating project failure
I solved it! The problem was in regional settings. I set it to US and now everything is okay.
Fix to the problem in desktop entries:
Exec=gnome-terminal -e "bash -c 'export LC_NUMERIC=en_US.UTF-8 && sudo /opt/Xilinx/Vivado/2014.4/bin/vivado'"
Community Manager
Community Manager
Did you make any modifications to the block design? If not, the project would have got corrupt.
Please try creating project from scratch and see if the problem persists.
check if you are using the tool version for which design was created
you can download design files from here
http://www.xilinx.com/products/boards-and-kits/see-all-bk-device-family.html
Thanks and Regards
Balkrishan
Visitor daveylib
I'm sure the project is pure and I use correct tool version.
I guess the problem is in the licenses. I've got evaluation versions of licenses.
`mys-xc7z020-arm-hdmi-xylon` project uses logiCVC-ML in 3.02.a version and logiCLK in 1.02.b version.
logicBRICKS offers evaluation versions of these ip cores, but only with 1.0 version limit, and that's why I get the errors.
MYiR tech support confirms what I said here (^) and claims I have to buy licenses.
It's weird and annoying, because on the product website they've written they are using evaluation version of Xylon's logiCVC-ML and logiCLK ip core. http://www.myirtech.com/list.asp?id=502
Visitor daveylib
