Vertex 5 Temac showing RX packet rejected
hi..
i am using vertex 5 hard Temac for ethernet communication.i am tryint to send ethernet data as per ethernet 802.3 standard where ip address is not a part of the packet.
i am able to send the data from the FPGA to PC but when i am trying to receive the packet it is showing RX packet rejected interrupt.but i am able to receive udp packet from the PC without any issue.
Re: Vertex 5 Temac showing RX packet rejected
According to the spec, setting bit 25 of the Receiver Configuration (Word 1) register will disable Length/Type checking on inbound packets.
Alternatively, you can set the attribute (below) of the instantiation in your hardware, and that should carry into the design and become the default value of the register bit.
-Joe G.
Where's the packet?  Show us the packet that gets rejected.
If you disable the Length/Type check, does the packet still get rejected?
Are you capturing all of the Rx stats?  Do they contain any additional information as to the reason for the rejection?
-Joe G.
thanks for the reply.
i am preparing the packet as per the attached image.means first 6 byte are dest mac addr,then next 6 byte are source mac addr,then 2 bytes are data length and rest all are zero..i am sending 90 bytes in total...i am using 2 temac..both are connected via a lan cable.from one temac i am transmitting and in 2nd temac i am receiving..when i am debuging Temacerrorhandler function is called and there it is showing RXpacket Rejected error.can you pls give some demo code on how to disable length check or address filtering for the temac..
thank you
-Joe G.
i will implement and come back to you..thanks
thanks ...it worked..
