Observer fisherjeff
Video Frame Buffer Write Data Corruption
I'm having a problem with the Video Frame Buffer Write IP on a Zynq UltraScale+ that I can't figure out. I have had it working in the past but something must have changed in my hardware design. If I roll the bitstream and DTB back I can see that it does work, but because I haven't been able to come up with a good way to use source control with Vivado (side note: any tips here would be very helpful), I don't know exactly what the differences are.
In my design, I have two different v_frmbuf_wr blocks: One is fed by a Video In to AXI4-Stream and the other by a TPG. Both exhibit the same behavior, where every other 8 bytes of data is zeroed out. Here is a partial hexdump of an NV12 TPG frame, for example:
00000000  ff ff ff ff ff ff ff ff  00 00 00 00 00 00 00 00  |................|
000000a0  e1 e1 e1 e1 e1 e1 e1 e1  00 00 00 00 00 00 00 00  |................|
00000140  b2 b2 b2 b2 b2 b2 b2 b2  00 00 00 00 00 00 00 00  |................|
000001e0  95 95 95 95 95 95 95 95  00 00 00 00 00 00 00 00  |................|
00000280  69 69 69 69 69 69 69 69  00 00 00 00 00 00 00 00  |iiiiiiii........|
I have deleted both pipelines and completely rebuilt the TPG pipeline from scratch, exactly (as far as I can tell) following the 2018.2 ZCU106 TRD but I still continue to see this behavior. Here are the relevant device tree elements, which I verified closely match the ones from my working bitstream/DTB:
&tpg_core {
    reset-gpios = <&gpio 82 1>;
    clocks = <&clk 71>;
    ports {
        #address-cells = <1>;
        #size-cells = <0>;
        port@0 {
            reg = <0>;
            xlnx,video-format = <XVIP_VF_YUV_420>;
            xlnx,video-width = <8>;
            tpg_out: endpoint {
                remote-endpoint = <&vcap_tpg_in>;
&tpg_framebuffer_wr {
    #dma-cells = <1>;
    compatible = "xlnx,axi-frmbuf-wr-v2.1";
    reset-gpios = <&gpio 83 1>;
    clocks = <&clk 71>;
    clock-names = "fclk0";
    xlnx,dma-addr-width = <32>;
    xlnx,pixels-per-clock = <1>;
    xlnx,vid-formats = "yuyv", "uyvy", "nv12", "rgb888";
vcap_tpg {
    compatible = "xlnx,video";
    dmas = <&tpg_framebuffer_wr 0>;
    dma-names = "port0";
    ports {
        #size-cells = <0>;
        port@0 {
            reg = <0>;
            direction = "input";
            vcap_tpg_in: endpoint {
                remote-endpoint = <&tpg_out>;
And here are the relevant portions of my block design:
I did verify that all the IP settings on my TPG pipeline are identical to the ZCU106 TRD, and even added the data FIFO just in case but nothing I have been able to do has changed the behavior whatsoever. Any assistance would be GREATLY appreciated.
Observer fisherjeff
Re: Video Frame Buffer Write Data Corruption
Okay, I've been trying to figure this out for WEEKS. Sure enough, I figured it out an hour after posting on the forum...
Apparently the AXI HP slave port on the PS must be 128 bits no matter what. In my case, my v_frmbuf_wr is running at 1 sample/clock, which corresponds to an AXI4-Stream data width of 64 bits. Accordingly, I'd thought that the right thing to do was to set the slave port to also be 64 bits, but it turns out I needed to convert to 128 bits at the interconnect and add a FIFO.
Observer fisherjeff
Not sure why these didn't come through the first time – trying again...
Observer fisherjeff
