02-19-2019 11:20 AM
I'm having a problem with the Video Frame Buffer Write IP on a Zynq UltraScale+ that I can't figure out. I have had it working in the past but something must have changed in my hardware design. If I roll the bitstream and DTB back I can see that it does work, but because I haven't been able to come up with a good way to use source control with Vivado (side note: any tips here would be very helpful), I don't know exactly what the differences are.
In my design, I have two different v_frmbuf_wr blocks: One is fed by a Video In to AXI4-Stream and the other by a TPG. Both exhibit the same behavior, where every other 8 bytes of data is zeroed out. Here is a partial hexdump of an NV12 TPG frame, for example:
00000000 ff ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 |................| * 000000a0 e1 e1 e1 e1 e1 e1 e1 e1 00 00 00 00 00 00 00 00 |................| * 00000140 b2 b2 b2 b2 b2 b2 b2 b2 00 00 00 00 00 00 00 00 |................| * 000001e0 95 95 95 95 95 95 95 95 00 00 00 00 00 00 00 00 |................| * 00000280 69 69 69 69 69 69 69 69 00 00 00 00 00 00 00 00 |iiiiiiii........| *
I have deleted both pipelines and completely rebuilt the TPG pipeline from scratch, exactly (as far as I can tell) following the 2018.2 ZCU106 TRD but I still continue to see this behavior. Here are the relevant device tree elements, which I verified closely match the ones from my working bitstream/DTB:
&tpg_core { reset-gpios = <&gpio 82 1>; clocks = <&clk 71>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; xlnx,video-format = <XVIP_VF_YUV_420>; xlnx,video-width = <8>; tpg_out: endpoint { remote-endpoint = <&vcap_tpg_in>; }; }; }; }; &tpg_framebuffer_wr { #dma-cells = <1>; compatible = "xlnx,axi-frmbuf-wr-v2.1"; reset-gpios = <&gpio 83 1>; clocks = <&clk 71>; clock-names = "fclk0"; xlnx,dma-addr-width = <32>; xlnx,pixels-per-clock = <1>; xlnx,vid-formats = "yuyv", "uyvy", "nv12", "rgb888"; }; vcap_tpg { compatible = "xlnx,video"; dmas = <&tpg_framebuffer_wr 0>; dma-names = "port0"; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; direction = "input"; vcap_tpg_in: endpoint { remote-endpoint = <&tpg_out>; }; }; }; };
And here are the relevant portions of my block design:
I did verify that all the IP settings on my TPG pipeline are identical to the ZCU106 TRD, and even added the data FIFO just in case but nothing I have been able to do has changed the behavior whatsoever. Any assistance would be GREATLY appreciated.
02-19-2019 12:59 PM
Okay, I've been trying to figure this out for WEEKS. Sure enough, I figured it out an hour after posting on the forum...
Apparently the AXI HP slave port on the PS must be 128 bits no matter what. In my case, my v_frmbuf_wr is running at 1 sample/clock, which corresponds to an AXI4-Stream data width of 64 bits. Accordingly, I'd thought that the right thing to do was to set the slave port to also be 64 bits, but it turns out I needed to convert to 128 bits at the interconnect and add a FIFO.
02-19-2019 12:01 PM
Not sure why these didn't come through the first time – trying again...
02-19-2019 12:59 PM
