Newbie tiannomad
Vivado 2014.4 - AXI EMC - data not correct in readback
I'm trying to interface to a 8-bit Asynchronous SRAM using the AXI EMC IP.and i use microblaze with EMC. The AXI bus is 32-bit wide, the memory bank databus is 8 bits wide. I'm debugging the AXI and EMC busses with vivado2014.1 and vivado 2017.3. If I issue write to the memory, I see one  write cycles to the SRAM.The address and data all ok. If I issue a  readback from the memory, I see four  read cycles, the address is four address, and the data in SDKis not correct.But on the AXI side, I see the s_axi_mem_araddr is only on address,one the EMC side the address is four address. i.e. if I read address 0x01, the EMC mem_a are 0x00,0x01,0x02,0x03. Have I got something wrong, or is this a bug in the AXI EMC block? If anyone could verify this I'd appreciate it.
The jpg is on my hardboard debug data.
I us 7k325t and vivado 2014.4,sdk2014.4
Newbie tiannomad
Re: Accept as solution
Hi:
This project is work ok when i use k6 and ise,but i see the read time and address is err.
thanks
