Warnings in XPS
Can someone explain me what is the reason for the below warnings in XPS and to resolve them.
I am attaching the MHS file. (FOR ML605 Board)
[ WARNING:EDK:4180 - PORT: Interrupt_address_in, CONNECTOR: microblaze_0_interrupt_Interrupt_address_in - No driver found. Port will be driven to GND - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_intc_v1_03_a\data\axi_intc_v2_1_0.mpd line 130
WARNING:EDK:4180 - PORT: s_axis_s2mm_tuser, CONNECTOR: ETHERNET_dma_rxd_TUSER - No driver found. Port will be driven to GND - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 255
WARNING:EDK:4180 - PORT: s_axis_s2mm_tid, CONNECTOR: ETHERNET_dma_rxd_TID - No driver found. Port will be driven to GND - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 256
WARNING:EDK:4180 - PORT: s_axis_s2mm_tdest, CONNECTOR: ETHERNET_dma_rxd_TDEST - No driver found. Port will be driven to GND - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 257
WARNING:EDK:4181 - PORT: Processor_ack_out, CONNECTOR: microblaze_0_interrupt_Processor_ack_out - floating connection - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_intc_v1_03_a\data\axi_intc_v2_1_0.mpd line 131
WARNING:EDK:4181 - PORT: m_axis_mm2s_tuser, CONNECTOR: ETHERNET_dma_txd_TUSER - floating connection - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 223
WARNING:EDK:4181 - PORT: m_axis_mm2s_tid, CONNECTOR: ETHERNET_dma_txd_TID - floating connection - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 224
WARNING:EDK:4181 - PORT: m_axis_mm2s_tdest, CONNECTOR: ETHERNET_dma_txd_TDEST - floating connection - C:\Xilinx\14.5\ISE_DS\EDK\hw\XilinxProcessorIPLib\pcores\axi_dma_v6_02_a\data\axi_dma_v2_1_0.mpd line 225
WARNING:EDK:4059 - INSTANCE: ETHERNET, Overriding connection of PORT: AXI_STR_TXD_ARESETN, VALUE: AXI_STR_TXD_ARESETN - which is part of the connected BUSIF: S_AXI - C:\Users\Sensor\Desktop\manoj\Work\modified_sx55\system\system.mhs line 327
WARNING:EDK:4059 - INSTANCE: ETHERNET, Overriding connection of PORT: AXI_STR_TXC_ARESETN, VALUE: AXI_STR_TXC_ARESETN - which is part of the connected BUSIF: S_AXI - C:\Users\Sensor\Desktop\manoj\Work\modified_sx55\system\system.mhs line 327
WARNING:EDK:4059 - INSTANCE: ETHERNET, Overriding connection of PORT: AXI_STR_RXD_ARESETN, VALUE: AXI_STR_RXD_ARESETN - which is part of the connected BUSIF: S_AXI - C:\Users\Sensor\Desktop\manoj\Work\modified_sx55system\system.mhs line 327
WARNING:EDK:4059 - INSTANCE: ETHERNET, Overriding connection of PORT: AXI_STR_RXS_ARESETN, VALUE: AXI_STR_RXS_ARESETN - which is part of the connected BUSIF: S_AXI - C:\Users\Sensor\Desktop\manoj\Work\modified_sx55\system\system.mhs line 327 ]
Re: Warnings in XPS
Check if below thread is helpful
http://forums.xilinx.com/t5/PCI-Express/Questions-about-axi-pcie-in-EDK-13-2/td-p/163380
Below AR can also be helpful
http://www.xilinx.com/support/answers/52791.html
Ashish
Re: Warnings in XPS
Have you checked this discussion and AR ?
Are you still facing any issue ?
Ashish
Re: Warnings in XPS
Hi Ashish,
I Checked your links. They dont exactly include the problem as above but suggests some ways to overcome these warnings.
As of now, i found that the _ARESETN should be connected to proc_system_reset module. But the base system builder does not connect these automatically. (because, I think it has to do something that the proc_system_reset module is connected to the lowest frequency clock of the system).
The links did not address the warnings related to interrupt and interrupt acknowledgement.
Finally I wanted to know the reason for these warnings. If the reason is known, a better understanding is obtained how to fix the problem. Since, these are only warnings they are causing any trouble the XPS design.
Thanks..,
