What does this warning "control reaches end of non-void function [-Wreturn-type]" mean?
I got this warning in my code:
What does this mean?
Re: What does this warning "control reaches end of non-void function [-Wreturn-type]" mean?
It means you have a function that's supposed to return some type of value, and there is a way for the processor to "fall off" the end of the function without executing a return statement.  Therefore the code that calls this function is expecting a return value, but it's possible the function will not return one and that's why you get the warning.  If that's how you intended the function to work because you guaranteed by design that not returning a value will not cause a problem, you can turn off that warning.  The warning in question is -Wreturn-type, so to specifically disable that warning you would add -Wno-return-type to the build settings for the Makefile.  However I would suggest you at least return zero instead of just turning off the warning.  Otherwise you may miss the fact that you forgot to put a return statement at the end of one of your functions.
Cheers,
-Doug
Cheers,
-Doug
Thanks, miss a return is the problem. I have fixed the codes.
