What happened to my AXI_IIC design? Bus stuck at busy.
I am using a simple ZYNQ CPU and teo AXI_IIC slaves.
Master DES_IIC has a GPO to enable iLA, and a slave SER_IIC is meant to receive.
Two jumper wires connects four pads outside the ZYNC chip.
The symptom I saw was the bus is stuck with SCL unable to continue.
while (1) {
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_RESETR_OFFSET, 0xA);  // soft reset
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_RESETR_OFFSET, 0xA);  // soft reset
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DGIER_OFFSET, 0x80000000);
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_DGIER_OFFSET, 0x80000000);
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_IIER_OFFSET, 0x86);
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_IIER_OFFSET, 0x28);
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_ADR_REG_OFFSET, 0x24); // RX addr to 0x01
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_RFD_REG_OFFSET, 0x00); // RX RX_FIFO_PIRQ Compare Value.
	XIic_WriteReg( SER_IIC_BASE_ADDR, XIIC_CR_REG_OFFSET, 0x1); // RX, Slave, 0, Enable
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_CR_REG_OFFSET, 0x3); // Reset, CR.Enable
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_CR_REG_OFFSET, 0x1); // CR.Enable
	XIic_WriteReg( DES_IIC_BASE_ADDR, 0x124, 0x0);
	XIic_WriteReg( DES_IIC_BASE_ADDR, 0x124, 0x1);	// Set GPO to enable iLA capture
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x112); // RX Addr
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x55); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_CR_REG_OFFSET, 0xD); // TX, Master, 0, Enable
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0xAA); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x11); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x22); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x33); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x44); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x66); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x77); // TX FIFO
	XIic_WriteReg( DES_IIC_BASE_ADDR, XIIC_DTR_REG_OFFSET, 0x88); // TX FIFO
	k=0;
	do {
		tmp = XIic_ReadReg( SER_IIC_BASE_ADDR, XIIC_SR_REG_OFFSET);
		aas = (tmp >> 1) & 0x1;
		srw = (tmp >> 3) & 0x1;
		k++;
	} while (aas == 0 && k < i_max); // As a slave or TO
	xil_printf("\r\naas = %2x, %8x", aas, tmp);
	if (aas == 1) {  // As a slave
		if (srw == 0) {	// Master write to slave
			k=0;
			do {
				rx_fifo_empty = 0;
				rx_fifo_empty = (tmp >> 6) & 0x1;
				k++;
			} while (rx_fifo_empty == 0 && k < i_max); // As a slave or TO
			tmp = XIic_ReadReg( SER_IIC_BASE_ADDR, XIIC_DRR_REG_OFFSET);
			xil_printf("\r\nReceived %2x", tmp);
		} else { // Master read from slave
} // While
回复: What happened to my AXI_IIC design? Bus stuck at busy.
I solved by adding pullup.
