Visitor heaooo
Who knows how to delay several milliseconds in MicroBlaze ?
I need  the executing program in MicroBlaze to  delay  several milliseconds (say 2 ms).  I use a C language while loop to implement it.
the C codes is like this:
counter=0;
while(counter<1000)
{ ++counter;   }
However, it's difficult to calculate the accurate time it postponed. The obstacles are
1) How  the C source codes  are complied to  machine instructions  is depended on compliers.
    Different compliers may produce  different  results.
2) For most instructions, it takes  a single  machine clock  to finish in a pipeline architecture, but some instructions, such     as memory access,  need  multiple machine clock to complete.
3)Specially, branch instructions will cause the pipeline to flush  instructions in fetch stage and decode stage, thus   increasing the latency.
If I want to delay an accurate time by means of  a while loop, rather than by a combination of timer and interrupt, is there a good way to achieve the goal, and does the Xinlinx EDK provide a utility  to evaluate the execution time of   a segment of C codes ?
Re: Who knows how to delay several milliseconds in MicroBlaze ?
I just looked for sleep/wait/delay functions in Xilinx libs like libxil but did not see anything helpful.
What I have done for these kinds of delays is to use the XPS Timer/Counter core and poll the TCR register until it has incremented by the desired amount.  If the CPU does not need to do anything except wait, this works, and avoids using interrupts.
Another approach would be to make a delay loop using inline assembly.  This would be predictable and should not depend on optimization, altho would probably be affected by caching.  For example:
   asm("LOOP1:");
   asm("addi r20, r20, -1");     // 1 clock
   asm("bnei r20, LOOP1");   // 1 clock if branch not taken, 3 clocks if taken
Jim
   asm("LOOP1:");
Jim
Visitor heaooo
Jim, thanks , I  appreciate  your reply!
There seem  not to  be  a perfect solution to the problem , unless  resorting to  Timer.
Historian
Historian
You really need to use a timer if you want any sort of accuracy.
