Participant nahol
Word addressing or byte addressing for the IP System Cache ?
Hello, I have read the documentation of System Cache without finding clearly if Word addressing or Byte addressing is used for the IP Core System Cache (I need to be sure, in order to determinate how many bits are used for the offset inside a 32 bit address) ? I assumed it is byte addressing, anyone can confirmed me this ?
Best regards,
Mathieu
Re: Word addressing or byte addressing for the IP System Cache ?
It seems information not provided in the pg131. I will report this so it will fix in future release
Thanks and Regards
Balkrishan
It is generic in nature but since cache line length is fixed at the moment it is 6 bits. But that is not something that affect the user.
 The Offset bits are 6 along as line length is 16. Index bits varies with cache size, associativity and line length
Thanks and Regards
Balkrishan
