XILINX TTC Stand Alone Driver Examples Problem
I started here...
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841648/TTC+Standalone+Driver
And ended up here...
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/ttcps/examples/xttcps_rtc_example.c
Pretty simple example. I can build this with the Xilinx SDK easily enough.
I built one version for RPU0, and another version for RPU1.
If I bring the target (ZCU102) up and run one or the other, everything is fine.
If I run one, then try to run the other, it fails.
Can someone else try this, I do not understand what is going wrong.
Either one will run fine over and over again however if I run either one,
and then try to run the other one, it breaks. It is always the second one that
fails regardless of which one I run first.
Teacher xilinxacct
Re: XILINX TTC Stand Alone Driver Examples Problem
@jrp
My guess would be that you are using two instances that have the same ID (or other common value). That may be causing the conflict.
Interesting... as it turns out, I fixed this
by removing the extra -DUSE_AMP=1 setting in the bsp's.
I must of picked that up from another project?
Now it works!
