Observer retni
XUartLite_Send problem, i can noly send 15 bytes char once..
I use the uartlite ip on zynq 7010.
I can send data to my pc, but the problem is only 15bytes can be send once no matter what 'NumBytes' parameter I set.
My code is like this:
	char *testWord = "1234567890qwertyuiopasdfghjklzxcvbnm";
	XUartLite_Send(&UartLiteDebug, testWord, strlen(testWord));
	while (XUartLite_IsSending(&UartLiteDebug)) {
	XUartLite_SendByte(UART_DEBUG_BASEADDR, 0Xd);
UartLiteDebug is the UartLite instance I defined.
I can only receive
'1234567890qwert'
 And I check the strlen(testWord) in debug mode , it is 36.
Please help me .
thanks!
Voyager
Voyager
Re: XUartLite_Send problem, i can noly send 15 bytes char once..
Hey @retni,
The Feature Summary for the AXI Uart Lite (PG142) lists ...
Generates a rising-edge sensitive interrupt when the receive FIFO becomes non-empty or when the transmit FIFO becomes empty. This interrupt can be masked by using an interrupt enable/disable signal. The device contains a baud rate generator and independent 16-character deep transmit and receive FIFOs.
So I wouldn't expect the XUartLite_Send() to be able to handle more characters at once.
Also, you do not check the return value of XUartLite_Send(), which is the number of successfully sent bytes.
I'd suggest to check the return value and break down long strings into smaller chunks.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Observer retni
thanks
Newbie vasukisoni
I have a basic doubt on the Uart application. I want to know that physically on the board, how are you making connection to the PC or a terminal to see uart messages. Can you please specify that for you board, which port and how are you connected to the PC via Uart ?
My board is UltraZed IO Carrier Card having Zynq MPSoC Ultrascale IP.
Please reply.
Vasuki Soni
hi
i have the same problem . i send 25 Bytes in my code with XUartLite_Send function but i Receive only 6 correct Bytes and 1 incorrect Byte.
for example i send
u8 Data[25] = {0xC0,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xC1} ;
but i recieve
c0 cc cc cc cc cc 00
please help me to solve this problem ...
thanks
