Xilinx Zynq-7000 SoC Video and Imaging Kit
My license will expire today and I want to confirm this statement "Node locked & Device-locked to the Zynq-7000 XC7Z020 AP SoC, with 1 year of updates". I can use Vivado Design Suite: Design Edition lifetime, right? The only thing that I will miss is the yearly updates and support.
If I want to purshase the system suite for only 1 year for this board, what is the required procedure?
Thank you
Re: Xilinx Zynq-7000 SoC Video and Imaging Kit
@yasemin.ali.87 Yes you are correct you can use it lifetime. You wont be able to use updated version once you reached the version limit of your license.
--> contact disti or online purchase on xilinx.com
http://www.xilinx.com/about/contact/authorized-distributors.html
-Pratham
