Observer mhsu
ZC706 Boot without external memory
I am using ISE14.7 EDK/SDK as my design tools.
I can download system.bit and run my elf file under SDK without any problem.
Is it possible to boot up or auto start my elf program after download bitstream?
Re: ZC706 Boot without external memory
The wiki page describes how to design a DDR-less system for XIP.  When no XIP, refer to AR56044  Here is another forum post that addressed this
You can program your boot.bin to your desired boot flash and run from there.    ISE 14.7 is a very old tool.  I would advise you migrate your design to Vivado.
Observer mhsu
Glena,
The application which I am working on can not use external memory(DDR/flash).
I am planning to use the internal memory of the Zynq.
How can I load the boot.bin into internal memory using JTAG and it will auto excute the boot.bin after down load the bitstream?
Refer to the Wiki
Observer mhsu
Could someone please help me to post the solution?
Thanks!
Observer mhsu
