Participant jqsam1
ZC706 board - Zynq on LwIP using Axi Ethernet sub-system (SFP)
Good Day all,
I was trying to bring up the LwIP application (bare-metal) from SDK 2015.4 (vivado 2015.4) using the axi ethernet subsystem (PL) through the SFP connector module and am unable to do it so far. I have instantiated the Cores based on the ZC706 board design automation and hook them up accordingly. As for the mgt_clk, i have reprogrammed the Si5324 Clock to run at 125MHz. I tried running the software, it was stuck at
------ lwIP TCP echo Server -------
TCP packets sent to port 6001 will be echoed back
*stuck
any advise would be helpful! Attached is the block design i have created.
Thanks in advance!
Re: ZC706 board - Zynq on LwIP using Axi Ethernet sub-system (SFP)
Hello @jqsam1,
Please check with this
http://www.wiki.xilinx.com/Zynq+PL+Ethernet
download the project and export to SDK. create LWIP echo server example application and test.
Best Regards,
Srikanth
