ZCU102 Board:Read from PL and write into PS through BRAM
I have tried with example design, how to read the data from PL and write into PS, but i am not able to read the data sequence to maximum. I am not sure whether the XSDK code which i wrote is right or wrong. Please guide me how to initiate the BRAM.
I wrote C code for Number series in XSDK, and trying to read those data in PS through BRAM.
XSDK code
int main()
    init_platform();
    static unsigned int seed =81924592;
    int result=2;
    uint32_t* ptrA = (uint32_t*) 0xA0000000;
    uint32_t* ptrB = (uint32_t*) 0xA0001000;
    xil_printf("START\n");
    while (1)
    if (result<seed)
    result *= 2;
    ptrB[result]=result;
    xil_printf("%d %d %d  ", result, ptrA[result], ptrB[result] );
    sleep(1);
    cleanup_platform();
    return 0;
Re: ZCU102 Board:Read from PL and write into PS through BRAM
I am not proper result in XSDK
Updated code
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h"
#include "xbram.h"
#include <xil_io.h>
void Numberseries(unsigned int *reg)
	static unsigned int seed =819242;
    int k;
    int result=2;
	//if(*reg<seed)
		//*reg+=1;
	for(k=0; k < 10;k++)
	if (result<seed)
	result *= 2;
	reg[k]=result;
int main()
    init_platform();
    int i=0;
    unsigned int count;
    static unsigned int reg=0;
    uint32_t response;
    xil_printf("Writing from BRAM ... ");
    for (i = 0; i < 10 ; i++)
     Numberseries(&reg);
    Xil_Out32(XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR + i*4, (reg+i));
    xil_printf("Reading from BRAM ... ");
   xil_printf("The value at address %x is %x\n\r ",XPAR_AXI_BRAM_CTRL_1_S_AXI_BASEADDR + i*4, Xil_In32(XPAR_AXI_BRAM_CTRL_1_S_AXI_BASEADDR + i*4));
    //response = Xil_In32(XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR+i*4);
    //xil_printf("value:%d\n\r", response);
        cleanup_platform();
        return 0;
Actual result should be like that 4,8,16,32...
