I have a design that use a camera associated with a MIPI CSI2 Rx Subsystem associated to VDMA IP Core.
I've used the mipi_example from Xilinx in Barematela, it does work fine.
Now, I want to use a Linux OS , I've added a dts insertion and I can see that Xilinx vdma driver is probed.
axi_vdma_0: dma@80100000 {
#dma-cells = <1>;
clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk", "m_axi_s2mm_aclk";
clocks = <&misc_clk_0>, <&misc_clk_1>, <&misc_clk_1>, <&misc_clk_1>, <&misc_clk_1>;
compatible = "xlnx,axi-vdma-1.00.a";
interrupt-names = "mm2s_introut s2mm_introut";
interrupt-parent = <&gic>;
interrupts = <0 106 4 0 107 4>;
reg = <0x0 0x80100000 0x0 0x10000>;
xlnx,addrwidth = <0x20>;
xlnx,flush-fsync = <0x1>;
xlnx,num-fstores = <0x3>;
dma-channel@80100000 {
compatible = "xlnx,axi-vdma-mm2s-channel";
interrupts = <0 106 4>;
xlnx,datawidth = <0x30>;
xlnx,device-id = <0x0>;
xlnx,genlock-mode ;
xlnx,include-dre ;
dma-channel@80100030 {
compatible = "xlnx,axi-vdma-s2mm-channel";
interrupts = <0 107 4>;
xlnx,datawidth = <0x10>;
xlnx,include-dre ;
We can see that VDMA Driver is probed and initialised correctly.
[ 4.424409] xilinx-vdma 80100000.dma: Xilinx AXI VDMA Engine Driver Probed!!
But, I don't know haw to use this driver to configure my VDMA to store frames in DDR .
The driver doens't create any character device to be used from usersapce.
Any help !
