Observer sridevi123
ZYNQ PS I2C ISSUE
I am working on ZYNQ Custom Board 7045. Currently I am trying to test PS I2C1(Connected to MIO32, 33) which is connected to RTC DS3231M. The Code is stuck in XIicPs_MasterSendPolled. I am not able to test further.
And CLK_FREQ its taking 50MHz. But as per TRM it should take CPU_1x clock which is 133MHz.
Can u please guide me what is the correct approach.
I have attached my code along with this mail.
Thanks and Regards
Sridevi
Re: ZYNQ PS I2C ISSUE
@sridevi123,
I2C SCL Clock = CPU_1X_Clock / (22 * (divisor_a + 1) * (divisor_b + 1)).
Could you check the clock in Vivado once?
Did you make any changes in the polled example?
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Observer sridevi123
I have attached xparameters.h file.  In that I am seeing I2C clock 50MHz.  It should have been 133 MHz.  I have not changed polled example. And In vivado I do not have any option to change I2C clock. I have attached my Vivado settings. Please let me know what is the issue.
/* Definitions for driver IICPS */
#define XPAR_XIICPS_NUM_INSTANCES 1
/* Definitions for peripheral PS7_I2C_1 */
#define XPAR_PS7_I2C_1_DEVICE_ID 0
#define XPAR_PS7_I2C_1_BASEADDR 0xE0005000
#define XPAR_PS7_I2C_1_HIGHADDR 0xE0005FFF
#define XPAR_PS7_I2C_1_I2C_CLK_FREQ_HZ 50000000
/* Canonical definitions for peripheral PS7_I2C_1 */
#define XPAR_XIICPS_0_DEVICE_ID XPAR_PS7_I2C_1_DEVICE_ID
#define XPAR_XIICPS_0_BASEADDR 0xE0005000
#define XPAR_XIICPS_0_HIGHADDR 0xE0005FFF
#define XPAR_XIICPS_0_I2C_CLK_FREQ_HZ 50000000
Sridevi
